Question about Optoma MovieTime DV10 Multimedia Projector
Dv 10 Lamp trouble
I went to turn on my Dv 10 today, only to find the lamp light glowing bright red.... does this mean the lamp blew?   I am the original owner and really only had about 400 hours on the lamp..... not that much use.....   I thought they were to last to about 2000 hours. It is still under 2 year warranty, but I have a feeling the lamp is not covered.........
Am I screwed?   The lamp seem to run $350-ouch!! Any thoughts.........
  • cyberneptune Feb 27, 2008
    OK- thanks for the help. I pulled the lamp out and really did not see anything that struck me as a fault. No crack, no clear blackened area...... can you be more specific as to what I might be looking for?
    Thanks
    Also- if I have to replace the lamp- is there any alternative to the $350 optoma charges for a replacemnt bulb?
    Cyberneptune
  • 27 Answers
Examine the lamp
any fault should be visible on the tube.
i assume you mean the pj lamp glowing bright red
Posted on Feb 26, 2008
Hi there its telling you that the lamb blow and you should think of getting a new one soon
Posted on Apr 15, 2008
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
Trouble shoot dash lights out in a 1997 Isuzu rodeo
double posted, why do that.
its answered already,
the "meter fuse"blew.
all warning lights out,
or do you mean the parking lamps out in cluster.
there are scads of waring lights, name some.
the CEL lamp tops list, if out the engine my not run.
does it run? do head lights work and all other lights.?
is the battery in car charged," top 12.6v rested. and you can drive say 10 mile with head lamps glowing full bright?
that be good to know.
Feb 04, 2015 | 1997 Isuzu Rodeo
Hc1500 projector will not turn on
Sounds like the lamp. The only way to really check it is to either put a new bulb in or put the old bulb in a different projector. Neither of which probably help you at this point. But, it does sound like the lamp is blown.
Mar 30, 2014 | Mitsubishi HC1500 DLP Projector
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
No picture on my sony kds-50a3000 red blinking light at lamp spot
If by noise, you mean a loud, audible pop--then it's your lamp that imploded.
You should be able to just pop off the cover on the side (right side if you are facing the front of the set), remove the internal lamp cover (if present) and yank (I mean, gently pull) out your lamp.
Look for all the bright particles of glass inside your newly imploded lamp. Replace with a Sony original, as these sets can chew through generic lamps very fast.
Now, if by noise you mean something else, please elaborate.
Jul 30, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
My sony kds-r50xbr1 turns on for a second then turns right back off no red lights flash. Today I just replaced the lamp and it was working fine for about an hour but then went back to the same problem.
If you already replaced the lamp and still have the same issue, that means you will need to replace your ballast, of course there is no need in returning the lamp, since eventually you're going to need one.
Jun 30, 2009 | Sony KDS-R50XBR1 50" HDTV
Sanyo PLC-XU33 image displayed for 10 seconds then turns off
Owner decided to upgrade to a newer projector. Lamp was too expensive.
May 07, 2009 | Sanyo PLC XU33 Multimedia Projector
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Hi there
Yes the lamp light means change the lamp. If you have not changed one in this tv yet it is overdue.
Jul 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Optoma MovieTime DV10 Multimedia Projector Logo
157 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
