Question about Frigidaire FEF366 Electric Kitchen Range
Frigidaire CFEF372ES1 White range with ceramic top elements- just bought the apartment and don't know how to unlock the oven door?
    President:
  • Frigidaire Master
  • 2,651 Answers
Its an electronic latch, try pushing the self-clean button, ti will try to lock and unlock the door- if successful the oven will begin to clean immediatly push the cancel button and will unlock,
Posted on Feb 26, 2008
Es510
Hello KC - You may try and reset the cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the lock symbol does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control), user interface board or a potential wiring failure. This is not a typicaly do it yourself job; please consult a professional or your manufacturer.
Apr 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Meaning of fault code F13 on Frigidaire range #cfef372es1 ?
Hello, welcome to FixYa.
I understand you have the Frigidaire CFEF372ES1 range, correct ? I also understand based on your post you're getting the F13 error message, correct ?
This range is built by Frigidaire as you know and a
ccording to their service manual, here's what it is and what you can do
...I will also add, **Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed fault code. **
...If you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset. That should do it...unless the EOC (electronic oven control) has failed.
Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Oct 27, 2011 | Kitchen Ranges
We have a ceramic top electric Frigidaire model GLEF378CCS. Neither the broil or bake elements work in the oven. Stovetop elements are fine.
check all wiring connections, if ok ohm out oven thermostat, if thermostat ok, ohm out oven elements and if ok, check voltage at oven elements. isolate problem.
Jan 25, 2011 | Kitchen Ranges
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I broke the ceramic top on my Frigidare Range. I
Hello, the top for your slide in would cost your $285.25 . First turn power off to the machine or unplug. To change the top you would open the oven door then remove the screws in the top near the door latch. You will have 3 or 4 screws one on the left the right and one or two in the middle section. The glass will then lift from the front and you will notice the surface elements will raise with the glass. You will have to remove the screws that hold the brackets and they you can just sit them down. Be carefull not to unplug any of the wires on the elements, and be carefull of the insulation. It will really cause skin rash. Once you have removed the elements you can lift the glass away and install the new one. I do have one new one available at my store. I can ship it to you for the price listed above. Please let me know if you have any more questions. You can also see me on ebay under the name AndersonAppliance2009
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Frigidaire fes365e Electric Kitchen Range
My oven is white with a black door. The elements
Here area few movies (for quicktime player)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF366 Electric Kitchen Range Logo
322 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
