Question about Kitchen Ranges
Oven issues When I use the broiler with convection, the broiler works, but the fan does not go on. When I use the oven with or without convection, the oven never lites. In convection mode still no burner, but the fan goes on. My first thought was to replace the glow igniter, but the fan running with the convection, and not with the broiler seems to present another issue. Would that be the circuit board not functioning properly? That's almost $ 300.00 for that part. Could the fan motor be bad also? The oven used to always work, it's just in the last couple of months that it's been intermittent. I've had the oven since new for about 6 years. Do I take it out to the garage & store tools in it or is there an easy fix for this?
  • 5 more comments
  • Foodguy Feb 26, 2008
    It is a Kitchen Aid Superba KGRT607HWH4. I also noticed last nite, that when I was using the broiler/convection setting, the fan would go on and off intermittently. I could hear a click, and the fan would start, then seconds later go off, then back on again. The click dis not seem to be coming from the fan, but from the front near the control panel.
    I will replace the igniter, as that explains the oven not lighting, but should that effect the convection fan running on & off when the broiler is working?
    Thanks
    I'm ordering the igniter right now! Thanks for the quick assistance!
    As you seem to have the right answers, one last item. Maybe this is just aging of the unit, but the glass top that covers the controls, which for the most part is spotless, has gotten increasingly difficult to use. Meaning it seems like sometimes when you touch on, off temps, whatever, the touch screen is not very sensitive at times. I try to set a temp, my wife tries, we wash & dry hands, have the neighbor try it, and its hit or miss. Do I need to get under the glass? Tricks? Hints?
    Could you tell me if there is a way to get the control glass more responsive? Its as clean as can get, but it seems like no matter what finger you use to turn on, set temps, etc, you have to try and try. Sometimes one press will do it, sometimes, i have to go through every finger on the block, til it works.
  • flesh_andblo Jan 08, 2009
    what does fan bake mean?>>?
  • Ron Coons
    Ron Coons May 11, 2010
    whose manufacture and model if poss
    President:
  • 1,314 Answers
Replace the oven ignighter
Posted on Feb 26, 2008
  • 1 more comment
  • robert samples Feb 26, 2008
    yes on broiler conv bake the fan runs when the oven is lit with the oven not lit then it runs when the broiler is lit which the broiler doesent stay lit all the time in broiler bake
    your welcome don't for get my rating it helps every time i answer if i don't get a rating it lowers my over all ratings thank you
  • robert samples Feb 27, 2008
    thank you
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
I have a 15 year old DCS 4 burner gas stove and oven. Slide in. The broiler stopped working today. Is it the broiler or the fan? How much are parts?
the likely cause is the hotsurface igniter has failed. not exactly sure how to check the part but you can check it voltage is getting to the igniter. if you have voltage, it's probably the problem.
Mar 20, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Broiler
can you hear the convection fan motor turn on? if not that would be your problem.
Apr 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
445 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
