Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Connection to my Computer with Printer
My Kodak printer is not being recognized by my computer
    President:
  • 2,351 Answers
Hello fosstone
Are you running windows Vista? Was the printer working at one time? If using Vista try this. Open Control panel, open system. Click on hardware tab, click device manager button. Scroll down till you see the yellow ! point. Right click on it once & choose update driver (a left click). A pop-up window will open. Choose No not at this time, click next. Click Install from a list or specific location. Click the Browse button. Scroll to your C:\ drive & click on it. Scroll down to the folder Window\system32 & click on it once. Click OK. With any luck windows Vista will re-find your USB & your printer.
Lastly, Microsoft may have created a fix in Vista update (KB940199). So run Windows Update just to be sure.
Please drop by & let me know if this helped.
Good luck fosstone!
Have a good day.
please vote...
Posted on Feb 26, 2008
5 Suggested Answers
  • 20 Answers
SOURCE: KODAK ESP 7. HAVING TROUBLE WITH PRINTER NOT BEING
right click my computer icon
Properties
hardware
device manager
double left click the universal serial bus controller
uninstall the usb composite device
Scan for hardware changes
Delete the printer icon in printers and faxes
Restart the computer
Posted on Apr 01, 2009
  • 214 Answers
SOURCE: kodak printer esp.3
It's what the internet is for Down load driver - install
Posted on Apr 22, 2009
  • 788 Answers
SOURCE: no connection with computer but printer is recognized
Try this, Disconnect the USB printer connection.
Remove the printer from the printer list. The list should be empty.
Re-boot your computer.
Check and make sure their are no other printers in list.
Find your install disks for the printer.
If you do not have a install disk, go to HP and download the printer installation files.
Install the software and do not plugin the printer until it is asked for.
After you install the new drivers and software the printer should be seen by the computer.
Posted on Sep 24, 2009
  • 11800 Answers
SOURCE: Kodak ESP3 printer will not connect with Windows 7
The printer no longer has it's driver installed. Unfortunately this printer doesn't have a driver for 7 so your only option is to try to install the driver for XP.
Posted on Jul 08, 2010
My computer does not recognize my printer
Follow steps strictly as directed by instructions. It should recognize the printer!
Feb 11, 2015 | Kodak ESP Office 6150 All-in-One Printer
http://resources.kodak.com/support/pdf/en/manuals/AiOPrinters/1K2682_SetupBooklet_5300_AMERICAS_WEB.pdf
Seeing as the problem is with your computer and NOT your printer it would be helpfull to know what OS you're using.
Go to printers and devices. Remove ALL the printers you don't have and all the Kodak printers you do have.
Load the Kodak install CD and follow the directions.
May 02, 2014 | Kodak EASYSHARE 5300 All-In-One InkJet...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a kodak 5052 wireless printer which my computer will not recognize. I have tried everything that I can think of to get the computer to talk to the printer to no avail. The printer is connected to my...
Normally you'd have a disc that came with the printer. It not only has a driver on it, which you may or may not need, but... it also will have a program for the computer to configure the printer for you.
You will probably find that the first time you need to connect to the printer with a cable FIRST to do the actual setup. That sets up the connection, printer wireless name, etc, and adds the printer to your list.
Then once that's all done and you disconnect the cable and reboot everything, once the printer comes on it looks for the router/hub, then you generally have a green light there indicating it's connected. Then you can print or do a test page from the computer.
If you don't have that disc, you should be able to download it from the manufacturer's website in Support and/or Downloads.
Good Luck!
:o)
Jan 02, 2011 | Kodak (844-5074) Print Server
I bought a kodak easyshare all in one printer and the driver disk wont read what do i do?
Pls check the printer cable that connect from cpu to printer, or try to replace the cable with the another one.
Sep 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
KODAK ESP 7. HAVING TROUBLE WITH PRINTER NOT BEING RECOGNIZED. CANNOT GET SCAN TO WORK AT ALL NEITHER FROM THE COMPUTER OR THE PRINTER ITSELF.
Properties
hardware
device manager
Mar 31, 2009 | Kodak Office Equipment & Supplies
SSID - computer cannot find the printer
You need the new driver, download from Kodak.
Vitally
Jan 11, 2009 | Kodak EasyShare EX1011 Digital Picture...
Sharing a Kodak 5100 All-In-One Printer
try this.............
On the computer that is connected to the printer:
  1. Open the Control Panel.
  2. Select Printers and Faxes.
  3. Right-click the KODAK All-in-One Printer, and select Properties.
  4. Select the Sharing tab.
  5. Select Share this printer.
  6. In the Share name field, type a name for your printer.
  7. Click OK.
  8. Right-click My Computer and select Properties.
  9. Select the Computer Name tab.
  10. On a piece of paper, write down the full computer name as it appears on the screen (for example: Johns Computer).
    NOTE: This is the name that you enter on the other computer(s) to access this printer.
On the other computer(s):
  1. Select Start > Run.
  2. Type two backslashes (\\) and the full computer name as it appeared on the first computer (for example: \\Johns Computer).
  3. Click OK.
    A window shows the new printer as the Shared Printer.
  4. Double-click the printer.
  5. Close all windows, then print to the Shared Printer.
Let me know if this helped.........
Dec 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
