How do I remove 1997 cadillac eldorado instrument cluster ?
Remove ac vents with flat head screwdriver . thair should be a 7mm bolt in each vent holding tha dash pad on remove them. remove the trim going to head liner from the dash pad. use a 7mm to remove the bolts holding the cluser in place should be one each side and 3 across the back . disconnect the wiring harness and your done. also disconnect the negative batery cable when doing this
Fig. Instrument panel cluster trim plate and related components-1997-00 Buick models
Fig. Front view of instrument cluster removal and rear view of the wiring harness connectors-1997-00 Buick models
