Relocating motherboard to another case
Dropped original case. All components are located in replacement case, having trouble fitting leads from HD DVD to motherboard, do you have a diagram for all plug connections to motherboard
  • 3 more comments
  • drawing Feb 26, 2008
    Hi Folks,
    Dropped Computer is a Acer aspire, model T135 motherboard is
    K8VM800MAE
    Hi Dropped computer is ACER Aspire model T135 M/Board
    K8VM800Mae
  • Kenneth  Keaton
    Kenneth Keaton May 11, 2010
    By more information,.. I believe they need at LEAST the model name and number from the origional computer.
    Or the model name and number from the motherboard itself.
  • Kenneth  Keaton
  • John  Turner
    John Turner May 11, 2010
    More information please
  • 35 Answers
This may work for you,.. for the most part the Gigabyte motherboard model number is the same... apart from the AE at the end.
( Which could very well stand for Acer Electronics )
Click Here .
Posted on Mar 16, 2008
  • 72 Answers
Try looking for the model number on the motherboard itself, and search for the manual on www.google.com or www.driverguide.com. I found mine on driverguide.
Posted on Feb 26, 2008
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
Its a Toshiba RD-XV49DT DVD/DivX/VHS Player/Recorder Combo, replaced power supply board as was blowing fuses found components have shorten out and now after replaced board, video works and i think hard...
The controller circuit (usually a small board connected directly to DVD drive - it is either part of the drive or a sub-assembly which is attached - and contains several ICs and small capacitors and a lot of surface-mounted components on its copper side) is probably faulty, possibly due to the original bad PSU (which you have since replaced), chances are the original faulty PSU has damaged this circuit - usually DVD drives operate around 12V DC or so. The digital controller circuit/board not only has the EEPROM/CPU etc. on it, but also has a servo supply - for the DVD (the VCR servo supply is on the motherboard). This powers the disc tray and traverse unit. The controller is not serviceable at component level; it must be replaced and in some cases, the DVD drive must also be replaced where the board is not separate to the drive. This may not be economical.
It may just be a simple case of a blown digital controller circuit - but be warned, this board is not cheap - it is part of a 'module' (the disc drive and controller together = DVD module), and you may not be able to obtain the board without a new DVD drive. Up to you what you do from here, and you might be lucky in terms of the motherboard and HDD - no damage there.
Apr 11, 2011 | Toshiba Televison & Video
I built a computer for my aunt using an Intel motherboard, Intel processor, 2 x 500MByte DDR3 RAM in a Blue Ninja case purchased from Tiger Direct. The computer worked well for more than two years then...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 16, 2011 | RaidMax Ninja Case (RDMXNJACAS)
INSTALLED NEW MOTHERBOARD FROM ASUS A7N8X TO P5S800 NEW BATTERY BIOS SCREEN COMES UP ONE LONG BEEP CONFIGURED TO BOOT FROM HD BUT ALL IT DOES IS GOES BACK TO BIOS SCREEN MAYBE JUMPERS ARE INCORRECT HOW...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 13, 2010 | ASUS P5S800-VM Motherboard
No power through mb. CPU and case fans start then stop. Monitor does not come on, HD does not kick. HD access light is constant. green light in back stays on, but computer does nothing else.
make sure this hard drive is getting power
Test or replace your PSU power supply unit
one bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
hope this helps?
Nov 28, 2010 | ASUS M2N-MX Motherboard
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
My Dell Dimension desktop 9150 was running very slow so I shut down the computer. When I pressed the power on button I notice that it was flashing. I pressed the button even holding the power button in...
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Oct 22, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Lost installation manual. specificaly wiring diagram
i damn sure didnt throw away 25 bucks; i guessed and got it.
Mar 23, 2009 | Sony Home Security
Upgrade PS2
well 2 things, 1 HD i don't think works on a PS2, but it does on a PS3 with a HDMI lead, also, playing copied games, watching copied DVD's and listening to copied CD's is illegal unless you have the originals of those discs, in which case use the originals or get ur ps2 chipped in a Computer fair (NOT RECOMMENDED)
May 18, 2008 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
417 people viewed this question
David Payne
David Payne
