Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
Digital Television We have a Sanyo CLT-2054, it has the description "EDTV" and was represented to us as being able to receive digital signals, is this so or do we need a convertor?
    Sergeant:
  • 308 Answers
You will need to use a converter box if you want to receive digital signals from an antenna as the tuner is not the ASTC (HDTV) type. Once you get a converter or cable box you can come out of it with component video cables and go into one of the inputs in the back of the set.
Posted on Apr 01, 2008
Remote control
Buy a original remote.Website 1-800-Remotes factory original.Get the original remote.
Dec 11, 2009 | Sanyo DS27510 27" TV
Tv mount for SANYO 2054
Read ur manual,go to ur tv website or go to Ebay.com or Amazon.com to buy ur model tv mount.
Sep 26, 2009 | Televison & Video
Will not turn on after bad storm
It's possible that your television set took a "Hit" from the storm and subsequently got "Fried". There's not much you can do for it now except replace it. For future reference, try plugging it into a surge protector first and then plug the SP into your outlet. The small "circuit breaker" should pop first, saving your appliances that are plugged into it.
Aug 17, 2009 | Sanyo Televison & Video
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
Have a Sanyo CLT2054 Have flickering picture looks like a strobe; sound is fine
Sanyo CLT 2054 flickering problem is a power supply issue. You don't need to replace it if you can desolder, and solder. Break the case apart that is connected to the ac power cord. Remove the aluminum cover from the DC out end of the PCB. Unsolder, and replace capacitors C9 & C12 (1000mf 16v). Super glue the case back together, and watch TV. Good Luck...............Don't use cheap capacitors use caps that have a low ESR.
Feb 25, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
I have a sanyo vizon flatscreen that the power cord was lost
I need a power cord for a sanyo flat screen t.v. model # CLT 2054. My email as follows is kellykingonly@yahoo.com . Please let me know if you can be assistance in anyway. Thank you.
Jan 08, 2009 | Televison & Video
Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
125 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
