Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
We have a GE Profile Oven (Spectra XL44) and really like the oven. Recently however it started to make a popping (or puffing) noise and a deep growling or humming sound while it is heating up to the set temperature. It also seems to take a little bit longer to heat up than it did before (15-20 minutes to heat upto 425 degrees).
Is this something we should be concerned about? Can anyone suggest something I can check or should I just call a service technician?
Dan
  • Dan Martin Feb 26, 2008
    Yes, your right I have a gas range. If it is a bad ignitor, would it continue to make a popping sound all the way up to the set temperature, every 30 seconds or so. Like its trying to restart the burner, then restart the burner, then restart the burner, etc.... or is there another sensor that reads the temperature that could be bad?
    What replacement should I tell them I need done?
    President:
  • GE Master
  • 2,651 Answers
Assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Posted on Feb 26, 2008
  • Ron Coons
    Ron Coons Feb 26, 2008
    popping entire way up to temp??? almost like bake bar is fluttering for lack of gas??? ignitor def releases gas from valve, and if not strong enough that would be a possiblity, no others sensors would be involved anly a pressure regulator, but then you would be experiencing issues broiling and cookin on surface burners as well
    Genius:
  • 3,422 Answers
You will definetly need a technician to fix this problem.I suggest you to call a technician and get the replacement done.Please visit THIS link.It is a GE website which will tell you different troubleshooting steps to fix your problem.
Goodluck..
  • Priya darshan Feb 26, 2008
    You have to tell him to replace the ignitor.
I have a GE Spectra Profile XL 44 and I get an code F0. What does that mean?
Here is a tip that I wrote that will help you with the Xl44 profile error codes.
Oven Fault Codes for GE XL44 Oven
heatman101
Oct 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44 repair - the oven will not self clean - regular oven works
heatman101
Jan 21, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 how do I lightthe oven pilot
heatman101 .
Jan 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra oven xl44 model # JGBP85WEB5WW oven will not heat
heatman101
Nov 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Feb 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,307 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
