Question about Sony Playstation 3 (PS3) Console
PS3 HDMI Our PS3 is not running at 1080p. We have a sony HD LCD TV and the PS3 and the two don't recongnize each other has being HD. They are connected with a HDMI cable.
Have you updated your firmware, earlier firmware had issues with HDMI cables and pic resolution. Make sure you have the latest firmware, I think its version 2.01 now. Also what kind of HDMI cable are you using, quality cable or some $10 jobby from Joe's Hardware Store. Check the cable with another device to eliminate that as a problem.
Posted on Feb 26, 2008
Sony KV-32FS13 TV no signal hdmi
Is ur tv a CRT tube type of a analouge tv u are asking?Yes than the tv don't have HDMI inputs hubs for HDMI cables connections.Only some projection tvs,all plasma,LCD and LED tvs have HDMI inputs hubs only and able give ur tv incomming signals HD 1080i for a broadcasting and HD pictures or throught a HD boxes or games devices like Xbox or Playstation 3 devices to get HD output picture for like 1080p.
Jul 12, 2012 | Sony KV-32FS13 TV
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
HDMI:
http://www.playstation3hdmicable.com/images/hdmi2.jpg
Component: http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
My TV or PS3 has problems?
reset the setting on the ps3 and that should fix it
Dec 04, 2009 | Sony Playstation 3 (PS3) Console
Cannot output 1080p with a full hd 1080p hdtv
In the settings menu, go to video settings. You can have the PS3 search for "optimal settings" This will tackle both video & audio.
On a side note, you didn't need to spend all that money a HDMI cable. ( I'll bet it's a 'Monster' cable, right? ) The $16 Phillips at walmart is just as good. Unless your doing "broadcast quality digital" work, the expensive cables are overkill. Sorry, bro.
May 18, 2009 | Sony Playstation 3 (PS3) Console
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Aug 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
