Question about Whirlpool Duet GHW9150P Front Load Washer
No heat in gas dryer
Hello....I have a Duet gas dryer...two years old.....No problems till today...now I have no heat when I run it. I checked the gas line and the exhaust and both are working. I unplugged it for 20 minutes to see if there was some type of re-start on it. When I turn it on, I don't hear anything fire or attempt to fire. Is there a thermocoupler type pilot? Any suggestions?
thanks
tom
  • bulldog1112 May 11, 2010
    do you have a picture of this igniter? i have the same problem with a duet front loading gas dryer model number GGW9200LW0. I have the front bottom cover off and have the dryer running but do not see this large tube with any ceramic pieces. Also I am not seeing this orange/red glow either, maybe it is my problem?? how much is this part? should i buy it then replace it?
  • 1,861 Answers
Remove the bottom cover (2 screws), and set it off to the side. Look into the right side (as you are looking at it) of the now uncovered dryer compartment. Here you will see a rather large tube. Behind this tube, you will see a flat ceramic piece (with several rounded edges at one side) with wires going to it. That is the igniter. Turn the dryer on & see if this thingy glows red-orange HOT. If not, remove it and look at the metallic portion. If any of the metal strips are cracked, the igniter is bad. Purchase a new one at your local appliance supply and bolt the new one back in. When the dryer is calling for heat, the igniter glows red hot, and ignites the gas. If it does not glow, the flame sensor is not satisfied and there will be no flame/no heat. I just replaced mine 2 weeks ago. Easy fix.
Posted on Sep 10, 2008
  • Whirlpool Master
  • 8,220 Answers
The thermal fuse is wired in
series with the gas valve. If the thermal fuseno heat in gas dryer - 69ecc7e.jpg
opens, 91°C (196°F), power to the valve is
turned off. A centrifugal switch on the motor
also opens the heater circuit.
Once the thermal fuse has opened, it will not
reset, and must be replaced. Check for a failed
thermistor and or air restrictions. Here is a duet service manual
These coils can go out:2e1dbeb.jpg
Usually if the dryer heats a little but quits it is these. You said you have no heat so it must be the duct fuse shown above.
Posted on Mar 02, 2010
  • Dan Webster
    Dan Webster Mar 02, 2010
    See page 67 or thereabouts
    President:
  • Whirlpool Master
  • 2,651 Answers
There is a thermal fuse located behind lower panel, then behind hte vent housing 2 side by side, black one thermistor(not your problem), whote one is thermal fuse. if it checks good for continuity then its good but most likely source, if needed i would the remove plugh leading to ignitor and insert meter leads ot dryer end turn on dryer listne for click and watch for 110v, if you got power you got a bad ignitor
Posted on Feb 26, 2008
I have an Admiral gas dryer. It's about 2 years old and today I noticed it is not drying clothes. It is turning on but there is no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101=-
Sep 18, 2011 | Dryers
Duet 7.0 runs but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer runs but doesn't heat?
If your dryer2_bing.gif is electric..
heatman101
Asker's Testimonial " Thanks for the feed back. Will order the part today. "
Apr 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore gas dryer runs but not heating
Try replacing the valve coils first, then the valve if the prior doesn't work. If there is a buzzing noise, I believe it's more likely the valve. I'm replacing both on mine to be sure.
Aug 18, 2008 | Kenmore Dryers
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
215 people viewed this question
Dan Webster
Dan Webster
Sal De
