Question about Akai LCT2715 27 in. LCD Television
Akai 27 inch LCD Broken crystal..
Hello Guys, I got this $600 dollar paperweight cause someone played football in the house and broke the lcd..Ive called so many people,none of which can help me find a new 27 inch Lcd to try and salvage something..It looks like the company went out of business but chimei optoelectronics name is on the lcd sceen itself..please help salvage the only thing new to me in years..thanks mary
  • Sunshine775 Jan 28, 2009
    Do you mean you can get a screen and change out the bad one and replace it with a good one?
  • 298 Answers
Unfortunetly, the LCD for this unit was never available per the manufacturer. You will not be able to find this at ANY parts distibutor. Your best bet is to search ebay for a broken one that has a good screen still. Best of luck.
Posted on Feb 26, 2008
Akai 55 inch dlp Tv
What is the problem of your
akai 55 inch dlp Tv?
Dec 23, 2011 | Akai LCT2715 27 in. LCD Television
When my 27 inch lcd with dvd is powered on, the screen pulsates fro 10 minutes then the flashing sound stops and all is fine
those akai flat panel tvs had several capacitors fail on the mainboard and the power supply board. you can see them vented on the top or bottom they will look like they are exploding.
Dec 23, 2010 | Akai LCT2715 27 in. LCD Television
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this...
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this problem
Sep 08, 2009 | Akai LCT2785TA 27 in. LCD Television
Akai flat screen lcd tv.. turns itself off after about 10 min
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Jun 06, 2009 | Akai LCT2715 27 in. LCD Television
I have a Akai 27 inch LCD HDTV will not Turn on
power pack most likely they blow capacitors all the time easy fix for some one who can solder.
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
I saw a tv at sams wholesale today for a reduced price but it stated that it had a broken crystal can this be repaired?
By crystal I would assume they perhaps meant a pixel on the display and that basically cannot be repaired cheaply (would require a new screen). However, if they were basically giving away the tV and you could ignore the flaw (there would probably be a small black dot that would never change) it might be worth a look.
Feb 27, 2009 | Akai LCT2715 27 in. LCD Television
MY TV 27 INCHES LCD DONT TURN ON ONLY THE RED LIGHT I WANT TO SEND FOR THE MOTHER BOARD WILL THAT FIX IT
I have repaired the same set nowadays. I have carefully re-soldered all the components on the Main Board (scaler board). The problem was the soldering material which is ROHS compliant...
A defective PSU can cause such a symptom too, especially the bad electrolytics is the most common problem with these sets.
Thomas
Jan 22, 2009 | Akai LCT2715 27 in. LCD Television
Akai LCD 27 in stand
According to Akai, the base stand for this unit is not available as a replacement part. You may want to try ebay for a replacment stand.
Apr 15, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
64 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
