Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer power button blinking won't print
Hi, I have a lexmark x1270 printer. It has been printing fine until this morning when there was a paper jam. I took the paper out, which was not jammed much at all, and the computer instructed me to shut off the printer and re-send my print job. I did all this and it does not work. The power button is blinking continuously and nothing is!
  • leafs_fan121 Jul 23, 2008
    we are trying to print some stuff out. out printer was out of ink for awhile and we finally got it refilled today. we followed the tips that were listed below, such as turning off printer for 5 mins from comp and wall outlet. still blinking occured and nothing else. we even tried pressing the paper feed button to no avail. what else can be done. help.
  • Wario123 May 01, 2009
    Yeah about a month ago mine also had a paper jam. I reinstalled the drivers completely wiping out the old ones. It still doesn't work. I even took the printer down from the shelf to insure there were no stray bits of paper down inside. There were none. Can someone explain this. Thanks a bunch.
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Posted on Jul 20, 2009
  • snshyne4u2c Mar 05, 2011
    Haha...I did everything it said to reset, even unistalled and reinstalled all the hardware and drivers. Still blinked..wasted time talking to a customer support that I couldn't understand and then...I read this! I took it loose shook it upside down and plugged it back in....walla it came on and NO blinking light. Maybe there was a piece of dust I don't know but it now works again. Hahaha...thanks!
  • 3,587 Answers
Unplug the printer from wall and computer..let it sit for 5 min, reconnect power only. run test page first..then plug in computer..
make sure that the paper run is completely open, by opening all the panels and doors that can be.
Posted on Feb 26, 2008
Press the paper feed button, it stops the on button flashing
Posted on Jul 20, 2008
2 Suggested Answers
  • 31 Answers
SOURCE: lexmark x1270 paper jam
hah - I had this problem on my old 1270 - there is a jam - its just very small - mine was caused by half a peanut lodged under a pickup roller - take the back paper guide off and check carefully - it might just be a piece of grit - the paper will skew away from the point of the jam so see where it skews and check around there
hope this helps, cheers
Posted on Dec 07, 2008
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Trying to cancel a print job on Lexmark X1270
I tried all the recommended solutions I found on FixYa but none seemed to work immediately. I decided to disconnect the printer from the PC for an hour or so and this did the trick. Not sure if that solved the problem, or the simply that the printer was working very slowly to delete the original printing request. However, I now know where to seek help in the future. Thanks anyway
Mar 30, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer not printing
ok..disconnect from computer..try restarting with hard power down(unplug from wall)..
turn on again..try to do a test page from front panel
Aug 18, 2008 | Lexmark X1270 All-In-One InkJet Printer
Power buitton blinking and wont stop.
have the same problem. power button keeps on blinking and paper doesnt go in.
Jul 23, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printing and coping problem has some of those options
Jul 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
U can try this...
Remove the power supply and replug it....
While powering and hold the paper feed button....and see what happens....If it prints a test page then....uninstall and reinstall ur lexmark software
Jun 03, 2008 | Lexmark X1270 All-In-One InkJet Printer
Ink levels/streaky printing
remove the carts & using a wet paper towel, clean the nozzles on the carts to see if your getting any traces of ink. U can also go to the solution center & under maintainence u will fine an option Clean to fix horizontal. try this twice that should also clear any blocks then try this
  • Printer power OFF
  • Hold down the PAPER FEED button while powering the printer ON
  • Release button after powering printer ON
  • Test is continuous, so turn off when printing is complete
If the cart has any ink it will print 3 color lines & a blk line
May 12, 2008 | Lexmark X1270 All-In-One InkJet Printer
It will not print when power button blinks, you must clear jam or reset until power button is on steady.
Feb 11, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
4,112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
