Question about Refrigerators
Any thoughts? Can't get fridge or freezer to cool down. First, started with ice cube maker not working. Tried to thaw freezer by keeping door open all night thinking that that line was frozen. We vacuumed the grate underneath. Now neither the freezer or fridge will cool down.
  • Anonymous Mar 09, 2008
    Icemaker stopped working and refrigerator and frezer side are not as cool as they should be.
    President:
  • Refrigerators Master
  • 2,651 Answers
Any noises from frig at all??? cicking humming???pull the unit out and remove back cover. Is the compressor(football)size motor in back hot to touch??Lights are on in frig right?
Posted on Feb 26, 2008
Why is ice frozen solid in the bin?
The ice could be caused by a partial thaw such as a power failure. To open bin unplug unit. Get lots of towels and a wet Vac if you have one. The use of these will become obvious shortly. Open the door and put a fan blowing on it, the same type of fan we use when it is hot to cool down. Then wait in time it will start thawing. This would also be a good time to clean it inside, you probably were putting that off. When totally thawed and dry start it up and keep an eye on it for a few days it will probably be ok. If not you have a clean unit to try some of the other suggestions.
May 27, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adora freezer on the bottom not making ice
It could be a couple of things. Check to see if the bar that controls turning the ice maker on and off is in the down position. Up is off. My ice makes water line froze in the refrigerator section; no ice and no clod water. Check to see if the cold water is working in the refrigerator section. If not, turn the refrigerator section temperature to 42, keep the door open until it drops to that temp, and wait 24 hours for the water line to thaw. The water and ice maker should start working.
Jul 12, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We accidentally left the freezer door just barely open overnight. The freezer started to thaw somewhat, but we caught the problem before anything had to be thrown out. In other words, there wasn't a lot...
yes ice formed in the bottom of the ice bin locking the auger from turning to dispense ice. Defrost the ice bin and wipe clear of any left over water from the melt.
Appliance 911 Sea Breeze
Mar 14, 2017 | Whirlpool Refrigerators
My LRSC26923TT side by side fridge/freezer has stopped making ice. It still dispenses water but it would not dump the last tray produced. I removed the cubes from the tray by hand, emptied the freezer, and...
Unfortunately, Ice Makers are notoriously unreliable and most require more expertise than a handyman possesses. Most require replacement of one of the 4 main parts (usually not generic): drive motor, water solenoid, heating release element or bin full ice arm control switch.
A Certified Technician should be able to diagnose the problem and suggest a repair or replacement.
Apr 22, 2017 | LG Refrigerators
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
