Question about Gateway FPD2275W LCD Monitor
X2gen 22 How do I open my broken X2gen monitor
  • tlyp Feb 25, 2008
    help
I am not sure why someone would explain how to open a DELL monitor when the question was an X2GEN monitor.
I know how to do this properly. The one I have is an X2GEN 19" MG19VT. I wish someone would have known what I know now so I would not have had to mark up the plastic. There are two screws on the back towards the bottom. Take those out and all you have to do is slide the whole plastic front part UP and it will come off.
Posted on Apr 02, 2008
    Novelist:
  • 138 Answers
Hi, I used to fix a monitor from Dell. There are 4 screws at rear panel and no screw at the front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, just face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this helps you to open you monitor. If there is anything I can help you with, feel free to let me know.
Thank you,
Tan
Posted on Mar 07, 2008
X2gen monitor power and all other front panel switches do not respond. i.e. power auto mute menu etc.. which caps do i need to replace to cure/
Robert,
Did you try opening the lcd ? all those switches connect to the power supply. I would go ahead and check and trace the switches with cabling to the power supply.
I just replace some transistors on 2 of these (22") and they work like a charm.
Al
Jan 05, 2014 | X2Gen MG19MY 19" LCD Monitor
Do you need a special driver for x2Gen 22 inch monitor with windows 7
You do not need drivers for monitor, just make sure you set the resolution output of your video card to the monitor native resolution and set the refresh rate to 60Hz. Make sure you do have win7 driver for your video card.
Jan 05, 2010 | X2Gen MW22U Monitor
Power lamp just blinks after power outage on my street
The post in following link fixed the same issue I was having with one of my 22 in X2Gen monitors. http://www.fixya.com/support/t2356502-x2gen_capacitor_location
Oct 07, 2009 | X2Gen MW22U Monitor
Monitor shows picture for 1/2 second then goes black, 22" display. also will not show display menus. have hooked another monitor up and works fine. also have hooked up to another computor and problem...
When you switch the monitors, do you still use the very same vga cable? If you don't, then it's time to change the monitor. When it turns on and off inmediately it means that it's receiving the signal, but that's it. If it's brand new, exchange it.
Sep 01, 2009 | X2Gen MW22U Monitor
X2GEN CAPACITOR LOCATION
I had the same problem with my 22" X2Gen, first the monitor started what looked like a random color temperature shift, ie the screen would switch between a yellowish and blueish tint, then it wouldn't turn on and the amber standy by light flashed on and off. I took it apart and replaced the 2 220uF25V capicators with 2 220uF35V caps I got at radio shack, part number 272-1029. Don't worry about the voltage mismatch I'm pretty sure it doesn't matter, the voltage is the maximum the cap can withstand and has nothing to do with the voltage in the circuit. The caps are located on the board that the AC cord plugs directly into, it has a plastic (almost feels like paper) sheild, the caps are marked C812 and C813 on the circuit board. There was no 47uF35V cap that I could find, anyway replacing the two did the trick, all for under $3, I almost went out and bought a new monitor ;) Hope that helps.
Jun 09, 2009 | X2Gen MG19MY 19" LCD Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
22" X2gen Screen Gone Black
Hi...there,
Well...You're out of lucks! Only mfg. carried this parts... But you can try to repaired it, by replaced a few busted capacitors... Good lucks!
Oct 30, 2008 | X2Gen MG19MY 19" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
126 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
