Question about Nikon COOLPIX L3 Digital Camera
The zoom is stuck outside
When i put the battery i can hear a small noise and the zoom is stuck outside it can not move.
    Genius:
  • 1,554 Answers
The 3 studs that allow the lens to move in a circular motion are jammed outside the track. it will require a complete dissemble to fix . most folks just sell it on ebay to a repair person.
Posted on Feb 25, 2008
Hx-1 zoom lens stuck in extended position
And you are sure, the battery does have enough power? because that could have caused the problem in the first place. But if it has enough power, you should check if anything could block the free movement of the lens barrel. Did you drop the camera, or bumped to anything, while the lens was out? When you don't see any damage on the outside, still it could be some damage on the inside, or a motor that won't work.
I should try to recharge the battery, and if after replacing the battery, the lens won't move, I should visit a service centre, or if a good photo shop is close by I would ask there with the camera in my hand, what they think of the problem.
Feb 08, 2014 | Sony Cyber-shot DSC-HX1 Digital Camera
Front wheel rubbing noise while moving
Just jack the vehicle to the side you hear the noise put a stand and turn the wheel with your hands and listen.I believe is not rim,possible is the wheel bearing. Give it a test.
Aug 16, 2012 | 2005 Chrysler Sebring Convertible
Zoom--mm blinking and can't change mode
Your zoom motor is probably stuck. Remove the two screws on the front side of the tiltable head. Pry off the two tilt caps using a small flat head screwdriver (they are glued on). Remove the 4 screws found under each cap. Now you can separate the two sides of the head and take out the two lenses (remember exactly how the lenses were positioned). Try pushing the flash in or out (it should move with a little force). See if the flash now responds before reassembling.
Mar 21, 2010 | Canon Speedlite 430EX TTL Flash
Canon sx20 problem
Hi there, dont use it. Because its a problem of lens giude pin. May be its damaged or some how there is some dust stucked. 54e194c.jpg
Another few reason is below.
Low battery or damaged battery can't afford to give that much power to motor. Or see the image below for lens problem.
I suggest you try to clean as per your risk or visit a canon service center. Thanks.
Mar 17, 2010 | Canon PowerShot SX20 IS Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
Jun 18, 2009 | Casio EXILIM Digital Camera
Ticking noise 2003 chevy silverado 4x4 1500 comercial
IT'S A BOMB!!! OH GOD YOU'LL BE DEAD WHEN YOU GET THIS.
May 18, 2009 | 2005 Chevrolet Silverado
Zoom lens noise in videos..
1 1/2 years, months, weeks? a little unclear.
you should not hear the zoom motor operate. you should not hear the result of its operation as elements move along.
you have a worn gear or contamination, or other defect. its probably minor. it happens.
return for service. its a good unit. but i would compare repair cost to replacement of latest comparable unit and then explore an upgrade option.
good luck
mark
Dec 24, 2007 | Canon PowerShot S2 IS Digital Camera
Olympus C-3000 Zoom telescoping lens problem
The small gears that link the viewfinder and lens may be out of sync. If you are a technical person, you can remove the frontcover, first taking off the topcover, (one screw is hidden under the mode dial). Power up the camera and remove the batteries when the lens is fully extended. BE CAREFUL NOT TO TOUCH THE CAPACITOR! Gently lift the viewfinder and move the viewfinder gear one tooth. It will probably only move one way. Put the batteries back in and try the lens. If this does not solve the problem, you may need to replace the lens or viewfinder.
Mar 20, 2007 | Olympus C-3000 Zoom Digital Camera
Strange mechanical sound from lens area
Cele, The noise you're hearing is perfectly normal. This generation camera uses a piezo electric focus mechanism to operate the lens. You will notice that the noise goes away if the camera is left alone for a moment while focused on a non moving object, this is because the focus adjustment is made and then the piezo circuit shuts down to conserve battery power. You should have no problems with this camera, it is very reliable. Hope this helps you. Joe Weibel customelectronics.org
Aug 31, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
