Question about Nintendo Wii Console
Wii remote won't work. Just lights up
I just got this used wii. I plug everything in and it get to the screen where I have to hit a button and nothing ever happens. the remote just blinks a few times and that's it
  • 50 Answers
Pair the wiimote with the wii. open the slot where the sd card goes press the red button then open the wiimote and press the red button right after
Posted on Feb 26, 2008
That should work. I tried pressing the connection button, and then none of them worked, then one, none, and then all. It might take a while, but so long as the Wiimote is not defected, then it should work
Posted on Feb 27, 2008
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
My Wii is not working. It will come on but the remote will not sync with the console (the hand does not appear on the scree). We purchased a new remote but it still is not working. We pushed the red...
You will have to update the wii to play newer games. Your controller problem if it does show a led light on the remote then its synced. If its just not showing you a hand on the screen then its probably your sensor bar. If your controller will not sync and all four leds flash then I would push the button on the console and push the button the remote then just try hitting the a or b buttons. I've also had to slap the remote after hitting the sync buttons to get it to sync. The update thing is normal though.
Jan 10, 2011 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
Wii remotes dont work on the tv screen replaced batteries in both remotes still does nothing
If you ahve checked for all possible obstructions or made sure tha tyour sensor bar is plugged try to re-sync your Wii remotes. Unplug your Wii for about 30 seconds and then plug it back in. Upon seeing the health and saftey screen hold down the sync button on your Wii console for 15 seconds. This clears out any previous Wii Remote Syncs. After that is performed open up the battery cover on the Wii remote you want to sync and hit the red button, soon after you do that hit the red sync button on your Wii Console. If it syncs properly the blue LEDs on the bottom of the controller will corespond to the # remote it has been synced to. Good luck.
Dec 29, 2009 | Nintendo Wii Console
Wiimote unresponsive to anything
Have you tried restarting the Wii and then synching the wii remote to the wii ?
Just below the disk loader is a hinge you can open to insert a sd card, There is a red button - Push it
Take the battery cover of the wii remote, their is a red button - push it
Push both buttons close together time wise
Aug 12, 2009 | Nintendo Wiimote & Nunchuk Controller...
My Wii Remotes Arn't Connceting To My Wii
I think you need to sync the remotes. Try this. Undo the battery cover and you will see a red button. turn on youre Wii and if you look at the front of the Wii you will se a littile panal. open it and you wil find another red button. Press it and press the one on the remote.
Jul 28, 2009 | Nintendo Wii Console
Wii remote
Greetings baggie bird,
You need to resynch your remote to your Wii console.
You hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Wii broken?
replace the batteries, and or try a friends remote.
Dec 31, 2007 | Nintendo Wii Console
Green Light on, but nothing working.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#shut_off
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
101 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
