I have a kenmoore fridge about 12 years old no problems ,but now I notice water on the floor on the fridge side not the freezer side. there is no water on the inside it appears to be coming from underneath please help
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you
pour it in. Good luck! :)
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
You have a clogged drain. If you have a top mounted freezer you might have the drain line on the outside of the fridge. Look for a tube that is thicker than the water intake line and goes from back of bottom of freezer down into the back of the unit to a drain pan. Remove that tube and take it outside and use your hose to shoot a stream of water to clean it out.
If you have a side by side fridge, your drain is still at the lowest point at the rear of your freezer. You may have to removed the rear wall of the freezer to get at it. Remove the back cover to get at the other end of the drain tube. It needs to be cleaned out also.
My mother's fridge had a leak on the freezer side in the front. I removed the cover below the doors and found a plastic coupling in the water line to the water in the door option, when anyone filled their glass with water the coupling leaked. I bought a new plastice 1/4 inch coupling and replaced the old one and the problem was solved. The coupling costs about $3.00 a Lowe's and it took about 2 min. to change.
The crushed ice sounds like the solenoid in the back of the freezer may be frozen and moving the mechanism (rod) even though you can move it by hand. Take a hair dryer and heat the area where the ice bin rod fits into in order to thaw the solenoid out. You can take the whole thing apart and put a little petrolium jelly on the shaft to keep it from freezing and sticking again if you have the tools.
The door alarm may be the door out of adjustment... hold the light switch down and see if that stops the alarm, if it does you can always glue an extension piece on the switch in order to reach the door again vice adjusting the door. Some of these models were very close to being out of adjustment and a few years of wear on the hinges could do that. I've even seen someone glue an extension on the door so it would press the switch better on closing.
As for the water leaking, is it continuous leak or say every 12 hours you notice a little bit of water? Continuous leak is likely a solenoid valve letting water by, small leak every 12 hours or so usually means the defrost drain line is clogged and the defrost water is not making it to the holding pan but leaking out the freezer compartment instead.
