Question about Samsung Digimax S630 Digital Camera
Drawing to much power over usb port
When i plug my camera into my mac it says that the usb device is drawing too much power and the usb port will be deactivated, so i haven't been able to move any of my photos to my comp.
  • dummydummy Feb 25, 2008
    well, i'm using the usb cord the camera came with, and i have a mac not pc.
I am having the same problem... and I have a Mac... everyone suggests getting a card reader for it instead of plugging it in directly. Inexpensive too.
Posted on Sep 12, 2008
  • 593 Answers
Use a USB port on the back of the PC, not off a hub, or use a powered hub, It cant take more than 500mw of power per USB port, even though there are 2 ports, they may be off the same controller inside the pc. I use a powered hub and have not had that problem ever since. I had a webcam that drew 450 and no other device worked off that port.
Posted on Feb 25, 2008
  • Steven Wander
    Steven Wander Feb 26, 2008
    Dont use the port on the keyboard as it is a low power port. and USB is standardized in its power output between Mac and PC.
Error message usb ports force stopped because of too much power
It will still be covered by the warranty, take it to an apple repair centre, they will have Apple hardware diagnostics software that will be able to determine the cause of the fault. Worst case scenario will be they have to replace the logic board.
If you are using some sort of USB hub the number of devices you are connecting to that single port may be drawing too much power. Try to determine how much power each device is drawing then ask at an apple store how much power the USB port can supply.
Feb 22, 2014 | Apple MacBook Mac Notebook
USB draws too much power. When I plug my Canon MP490 2.0 printer cable USB into my computer, a notice pops up stating: "Because a USB device was drawing too much power from your computer, one or more of...
in to the PC or into a hub, hubs are bad, they are lower power.
is this desk top, what is it?
ok , its 400mA max
so unplug all USB device and for sure CELL chargers.
there are only 2 possibles
PC has USB overload, too many devices.
or the PC is bad.
did you try all PC USB ports? 1 by one, all empty to start?
Sep 04, 2013 | Canon MP490 InkJet Printer
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Compatible charging cables for phillips go gear hdd1630/17
Apr 10, 2013 | Philips HDD1630 MP3 Player
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    Downloading
    Use the USB ports that are on the back f the PC, not the front ones or the one on the keyboard, these are low power USB ports. You can also purchase a powered hub that supplies its own power. The maximum draw on 1 USB port is 500ma, shared across all devicesattached to that port including non powered hubs. My USB PC-cam took 450 all by itself!
    Feb 14, 2008 | Photography
    Usb to serial adapter question
    Try installing the Wacom USB drivers on the Mac. As I understand it, this adapter is designed to interact with devices that have their own serial drivers installed--such as a PDA, cell phone, camera, etc.--not necessarily with an input device, such as a drawing tablet, game controller, or pointing device. YMMV.
    Dec 09, 2007 | IOGear (G-UC232A) Serial Adapter
    Samsung Digimax S630 Digital Camera Logo
    98 people viewed this question
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Computer Links
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
