Toshiba CX3583A Relay clicks sometimes it stays on sometimes doesnt turn on at all cannot figure it out
  • 47 Answers
47uf 50 volt capacitor on mains side of power supply do not open if you have no idea what a switchmode power supply is or how it works.
If you don't take it to a repair store.
Posted on Feb 26, 2008
Nissan 2002 Pathfinder is draining its battery
If it's clicking, it's not a fuse , its a Relay. Relays Do sometimes stick. Or it can be clicking due to low voltage that was caused by something else.
To see if that's your issue, charge the battery, take the Relay out of the car and see if the battery stays charged after 12 hours.
If teh battery stays.. then first step is to replace the relay.
Dec 24, 2012 | 2002 Nissan Pathfinder
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Philips 42PFL5603D/10 relay clicking
Relay is on or connected to power supply--if clicks on and then off something (most likely on power board or something it feeds) is bad.
Some voltages from standby portion of power supply can be tested but since no paper schematics for this brand it will be hard.
Jun 11, 2012 | Televison & Video
Display inop 4th light on base doesnt stay on
Do you get the Toshiba logo? before it goes black, if that is so the hard drive is more than likely the problem, first! remove the hard drive and reseat it back in place, sometimes this will restart the hardware, if no change! have it tested.
May 08, 2012 | Toshiba Satellite X205-S9359 Notebook
If i go to restart after i turn it off it won't restart
These cars have a main relay. I would replace it ASAP. This may not be the problem but if you do nothing and wait till it doesnt start you may end up stranded somewhere. Other than that if the car works no one will be able to figure it out till it quits for good. You could have someone check the fuel pressure and ramp the fuel pump for proper function. Sometimes a fuel pump that is failing will show a bad electrical pattern in a graphing meter
Mar 03, 2010 | 1990 Honda Civic
My toshiba A200 screen occasionally turns black and music also stops. When i try manually restarting my laptop, sometimes it works but most of the time it doesnt boot at all. Sometimes it doesnt even go...
This sounds like a hard drive is, or has failed. Either that or the RAM (memory has gone bad)
Did you let the laptop overheat? Was it left on for a long time? Or is this just an old machine ?
I would replace the hard drive, and reload the operating system, that is if you really want to keep the laptop. If that solves it great! Also, did you notice if there are any "beep" noises, or error messages when it acts up? Often times, you can go on the internet and find out what the messages mean.
Jun 17, 2009 | Toshiba Satellite A200-0ET00X Notebook
Connection to fuel pump relay
try a new relay or a new relay box your connectors could be burnt
May 31, 2009 | 1997 Saturn SC
Starter problem the car doesnt turn over..and the starter doesnt even click..
have you checked you your spark plugs and your plug wires make sure your getting gas to the engine also
Nov 08, 2008 | 1993 Toyota 4Runner
TV won't power on
Your model doesnt have a bulb. It has 3 CRTs instead. Sounds like something minor in the start up voltages. thereby allowing the start up relay to click then other times the relay doesnt click. So its either standby or start up supplies where the fault is. You can get a manual here at this link and also free support to help you figure it out.
http://servicemanuals.vstore.ca/
Mar 18, 2008 | Samsung HCL4715W 47" Rear Projection...
Coding to the dvd player remote.
not sure you could code it to the dvd remote or not but you can get a replacement remote from here that would work on your tv
http://replacementremotes.com/store/productdetailp.cfm?productid=17889
riz.
Oct 21, 2007 | Sony DVP-NS55P DVD Player
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
