Question about Dell Inspiron E1505 Notebook
Keyboard i have a dell inspiron e1505 and by accident tring to clean the keyboard rubbinh alcohol spilled on it. it was not alot but it was enough to make the keyboard not work. only 4 keys work and the others dont. is there any way to get the keyboard werkin again.
  • mpersaud
    mpersaud Mar 12, 2008
    ill definiteoly get back to u and hopefully this is a fixya!
    thankx much
    - mpersaud
Posted on Jun 21, 2008
Try taking your keyboard out and soak it in hot water for 30 minutes. Let it completely dry and then plug it back in.
Posted on Apr 15, 2008
  • 58 Answers
try to reseat to take the keyboard out and blow it dry or clean it or something. click here: http://support.dell.com/support/edocs/systems/ins6400/en/om/parts.htm#wp1076839
then reseat the cable as well. check if it is still doing the same thing, then the keyboard needs to be replaced.
revert back to me if you have any questions ok?
Thanks,
Karlox :)
Posted on Mar 12, 2008
How to replace a keyboard on dell inspiron e1505
The Inspiron 6400 and the E1505 share the same disassembly guide. Follow the link below to see an illustrated view of this procedure.
http://ahwee.com/how-to-disassemble-laptop-insp6400
Jun 01, 2010 | Dell Inspiron E1505 Notebook
My dell inspiron E1505's screen only half showing
Generally an indication of an LCD failure. You can try reseating the LCD cable under the keyboard, see if it makes any difference. If no change, then replace the LCD
Oct 01, 2009 | Dell Inspiron E1505 Notebook
LOOSE LEFT CTRL AND SHIFT KEYS
Generally, the keys on a portable keyboard are non-repairable. The keyboard is a Customer Replaceable Unit (CRU) and if under warranty, Dell should send a replacement, If out of warranty, Ebay is a good source for a keyboard and they generally run about $20
http://cgi.ebay.com/New-DELL-inspiron-Keyboard-630M-640M-E1405-E1505-6400_W0QQitemZ260372955660QQihZ016QQcategoryZ31512QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 23, 2009 | Dell Inspiron E1505 Notebook
0, o,k key doesn't work
The best thing to do is to disconnect the keybaord and put it on a radiator or in front of a fan, or, better, both. You can also use a bag of rice, which is a great desiccant (just saved my iPhone last week with this trick). The rice pulls in water from the surround air and will literally **** the water out. I'd really suggest putting it in the diswasher first though then dipping it in a bath of rubbing alcohol (to displace the water, shaking it and repeating this about 5 times and then putting it on a radiator with a fan infront of it. Or, rip it out and replace it on ebay for about $20.
Jan 30, 2009 | Dell Inspiron E1505 Notebook
Dell notebook keyboard malfunction
try to press the key using screw driver or any pin that you can press into the keyboard..but remove first the top key..try pressing with some screw if its typing,if not its mean the logic board is damage and you need toreplace a new one...if working with the screw pressing..repalace with a key button only with the same lock.
Jan 04, 2009 | Computers & Internet
Keyboard Malfunction
Does the laptop have a touch pad type mouse device on it? If so, you might accidently be hiting the touch pad with the sides of your palms or thumbs while you are typing a document.
Nov 10, 2008 | Dell Inspiron E1505 Notebook
Water damage
what are u using now then ?
by a new key board
Sep 14, 2008 | Dell Inspiron E1505 Notebook
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Jul 21, 2008 | Dell Inspiron E1505 Notebook
The whole keyboard
just wait as it may dry out .
if not a keyboard can be order on ebay for around 30.00
Feb 25, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
162 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
