Question about Car Audio & Video
Wiring an alpine cdm9807 rb to a citreon berlingo van
How do i do it please? Ive earthed it and also connected battery lead to positive on van battery. Buttons are lighting up on car stereo but nothing on main screen. Theres an orange wire; 'illumination', a pink and black wire; 'audio interrupt' and a blue and white wire; 'remote turn on' all no being used, perhaps one of these three is supposed to be connected? can anyone help? Many thanks.
The 'illumination' wire is to hook up to your headlight switch to back-light all buttons when headlights are on. The pink and black audio interrupt I believe is for hands free cellphone communications it will cut out audio when you have a call and have your hands free hooked up through your stereo. The remote turn on is for external amplifiers it provides a small amount of power to to turn on/off external amplifiers. As far as your unit not working I would make sure you have a sufficient ground using a voltmeter and make sure your battery lead is fused and fuse is not blown. You should have a memory lead(maybe yellow) that need constant 12v and a ACC power that needs switched power that is only on with key(usually red). Hope this helps! :)
Posted on Feb 26, 2008
Citreon Berlingo van. Need to unlock radio but dot have the code,can thius be done.
u can buy an unlock code on ebay from £2.99 you will need to take out the radio from the dash to get the serial number.
Jul 01, 2015 | Cars & Trucks
Need to know where the positive wires that connect to the battery of a '95 Toyota previa connect.
Hi
The black wire will be connected to the body or engine of the van and the red or positive wire is connected to your starter motor.
You can also use a 12 volt battery light to check the negative or positive wires.
You take the 12 volt battery light and place the negative black wire clip to an earth on the vehicle, then when you touch the tip of the 12 volt battery light onto a positive wire the light will light up.
Then you will know which wires are negative or positive sometimes the key has to be on for some wires to work.
Cheers
Oct 10, 2012 | 1995 Toyota Previa
I drove my 2001 SEL Ford Windstar van home Thursday night and Friday morning when I tried starting the van not one thing happen; no sounds, no lights, key would not unlock the doors, not nothing. My...
Hi
It sounds like a broken earth wire, check the main one from the car battery to the car bosy, or to test it get a thick cable roughly the same as the "black" earth lead from the battery attach it to the car body somewhere and the other red to the battery terminal if the car starts you know it is an earth problem. they do often break off the gearbox on these models, so do check. there will be 3 main earth wires in total
Regards
Dan
Dec 28, 2010 | 2001 Ford Windstar
VW POLO 1.9CL Diesel 1997 wont start
hi from uk check the main lead from battery+positive to the starters solenoid is secure ? also there is a thin wire that also connects to solenoid on a terminal of its own this is the solenoid energizing wire that works starter when key start position is selected if all above is ok? then use a jump lead and connect one end to battery negative post then the other end of lead to a suitable earth point on engine ? then try starting? if it works/starts ? you have a bad earth connection to engine from battery negative lead check the earth lead connection at point on engine is clean/secure ? it usually is secured by bolt at point where engine and transmission connect ? hope this helps?
Mar 26, 2010 | 2001 Volkswagen Golf
I have a Alpine SWE-1000 subwoofer with no wiring diagram. Ive sorted the power, earth and speaker cables but one remains ! The cable is a single blue/white stripe, any idears ?
No i do not have a wiring diagram for this exact Speaker but this speaker is self powered yes?
This blue and white lead is your remote turn on lead, this allows the amplifier to switch on and off with the vehicle, instead of just being on all the time and drain your battery.
This wire should be spliced in to an accesory that turns on and off with the flip of the ignition switch. If you could It would be best to splice it to the radio turn on lead. On your radio, there is a lead that should be labeled remote if it is aftermarket. If it is stock then you have to use a volt meter and back probe a lead until you find one that switches on with the igrnition switch, you should get one with battery voltag(12v or more) and one a ground (.11) and one with battery voltage when on and no voltage when off(this is the one you want to splice in too.
Jul 19, 2009 | Alpine Car Audio & Video
Alpine ina-n333r head unit shows .,navigation innoperable .
it needs to be connected to the p brake sensor wire near the e brake to work its a wire that goes to ground when you apply the e brake
May 19, 2009 | Alpine Car Audio & Video
Van alarm is draining battery flat over night
I doubt it is the alarm, but a simple way of checking is to unplug it.. look under drivers dash for an aftermarket box, unplug the connections (after charging battery) and wait till next day.. I think you might have a diff issue (I have installed these for over 10 years and never seen one actually discharge a battery)
Jan 18, 2009 | Crime Stopper Vehicle Parts & Accessories
Car amp problem
make sure the front left wires arent shorting out if they are they could be causing the amp to overheat and shut down till`s its cooled ehough to restart
Apr 01, 2007 | Alpine MRV-F540 Car Audio Amplifier
Car Audio & Video Logo
267 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
