Question about Jenn-Air 36 in. CCG2523 Gas Cooktop
Converting stovetop from natural gas to lp
I've changed out the orifices and purchased a Maxitrol regulator from Maytag ..rv47cl 1/2psig nat 5.0"LP 10.0" : Y704545. My question is, do I need another regulator besides this one? as there seems to be too much pressure on the regulator. Because with just this one regulator there is still too much pressure.
I have a 30 lb bottle attached to the stovetop with a 3/8" to 1/2" line.
Thanks,
Phil Sorrell
email is : gingin@wildblue.net
  • 2 more comments
  • ohiogas Feb 28, 2008
    thanx! tech17.... got it under control finally! the regulator they sent me was just specifically for lp gas... no flip in it. so i did add the additional regulator and it's working fine. thanx again for taking the time to help out ! ohiogas
  • Anonymous Mar 13, 2008
    I have a Creda 4 burner gas. Converted to LG, and installed a maxitrol regulator RV47 CL, I have already changed the inside plunger to LP and re-attached the spring...However, I have readjusted the internal setting of the regulator, and have forgot what the original setting was.
    My flame is blue, with little yellow tips showing at times...Only on the large burners...
    What is the proper flame setting ???
    Thanks
    Mike
    what is the proper flame setting of LP burner?
    what should the flame look like ?
    should it be a blue flame ?
    or
    should the flame have some yellow on the tips ?
    President:
  • 1,314 Answers
There is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
Posted on Feb 26, 2008
How do u change a gas stove from natural to lp?
Nearly every natural gas / LP operated appliance can be converted to work with the other fuel pretty easily. You will need to change the orifice in the burner & pilot. Contact your LP provider and they should be able to supply the correct parts / perform the labor for this job for you.
Feb 19, 2013 | Whirlpool Stove / Oven / Range Cooktop -...
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
The regulator seems to be closing off completely, and not flowing gas (LPG). We have converted cooktop from natural gas to propane per instructions manual -- changed orifice spuds, converted regulator and...
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
Feb 06, 2011 | Maytag MGC5430 Gas Cooktop
Mod jgp328wec2ww changed orifices from nat to lp. Burners not getting hot enough. It took 12 min to bring 1 qt to boiling and not rooling. how is this adjusted?
Please tell us everything you did to convert your stovetop/oven to LP? Beside swapping the natural gas orifices for LP orifices, did you also switch the appliance regulator over to LP? When you put in the orifices did you match up the proper size ones to each different size burner according to your owner's manual? They have #'s stamped on them to identify them and some are even color coded. Were you having any similar issues with your previous stove? If so, it may be a pressure problem. I can help you solve this problem with a little more information. Douglas
Oct 05, 2010 | GE Cooktops
Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Aug 06, 2009 | GE Cooktops
KitchenAid 5 burner Cooktop conversion to LP gas
you need orifices for lp and the regulator should be convertable there is a "plug" thing in the middle of it that you remove and turn over and install
Apr 15, 2008 | Cooktops
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Convert to LP?
If it is possible, then the orifice has to be changed. The regulator may need to be changed as well. I am a certified LP technician for recreational vehicles, but I don't know enough about this particular appliance to say for sure if it can be converted. The best thing is to contact Miele directly, but this sort of conversion always requires a different orifice. Note that propane, butane, and natural gas are all forms of LP (Liquified petroleum), so conversion between the 3 is usually possible
Oct 15, 2007 | Miele 35 in. KM326G Gas Cooktop
Convert to LP (propane)
Contact Miele directly via their website. This would require an orifice change if it is possible for this appliance. Since natural gas, butane, and propane are all forms of LP (Liquified Petroleum), it is usually, but not always, possible.
Jenn-Air 36 in. CCG2523 Gas Cooktop Logo
1,586 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
