Question about HP iPAQ rx1950 Pocket PC
Windows player cant recognise the sd card, therefore iam uable to synch music on my sd card
  • 29 Answers
1st approach (Quick one!)
1. Soft reset your device
2. make a backup copy of the folder \SD-MMCard\MSMETADATA if exists.
3. delete the folder \SD-MMCard\MSMETADATA.
4. Soft reset your device once again.
2nd approach (Long one!)
If 1st approach did not work, restore the MSMETADATA folder and try the following:
Step Zero: BACKUP
- Make a full backup of your device (including storage cards). If you don't like to do a full backup keep at least a backup of all files and folders we are going to delete as indicated below:
Step One
-In the main device directory delete the file WMPInfo.xml
-Delete the \Application Data\Microsoft\Media Player\ directory and all of
the files in it including the WMDRM folder.
-Delete the \Music folder
Step Two
-Go to your SD card main directory and delete the file WMPInfo.xml
-Delete the folder \SD-MMCard\MSMETADATA
-Delete the folder \SD-MMCard\WMDRM
-Delete the folder \SD-MMCard\Music
Step Three
-Repeat step two for any other storage cards.
Step Four
-Refresh devices in WMP and the storages card should show up in the left tab
and in the sync window you can click "Next Device"
Hope this helps...
Posted on Feb 26, 2008
Can i use windows vista with my ipaq 3835 pocket pc and what is till the memory expandable upto
No, you cannot use Windows Vista on your iPAQ.
I am not 100% sure but, I have seen products made before the whole HD SD cards not being able to use them so, I would stick to the regular SD cards which go to 2GB.
Feb 09, 2010 | HP iPAQ H3835 Pocket PC
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
check if your SD is SD HC because it cant read HC
Nov 04, 2008 | HP iPAQ HX2490 Pocket PC
Wi-Fi SD card
Hey, id be happy to help :), the reason why your SD wifi card is not getting read by your pocket pc is because. The wifi card you have is probably have was made for a regular computer and is not compatible with your pocket pc. Id recommend for you to find a SD wifi card that is compatible with your pocket pc. And return the one you have now, thanks and I hope this helps!
Aug 29, 2008 | HP iPAQ H2210 Pocket PC
Media Player won't read storage card library
I gave up and bought ($23) Conduit's Pocket Player which has no problem seeing and reading my MMC card which I sync to from Media Player on my PC through the PC's card reader. Job done!
May 24, 2008 | HP iPAQ HX2490 Pocket PC
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
Saving music on my micro sd..
The only way the music can be played on a cell phone is if it is in mp3 format. you also have to list the songs individually (they cannot be separated into folders). to listen to the music you should have some sort of music player on the phone that will play the songs.
Nov 24, 2007 | HP iPAQ H1910 Pocket PC
Hp IPAQ H4150
thanks for the post. the first thing is to install the ipac software and try see if the syetm can sysnc. when properly configured there should be an ipac icon in my computer, open this folderand other sub folders will be visible,if you have an SD card media in this device it will be visibleas well. try copy the music of your choice from the system into the music folder or your sd card depending on your pref.
Aug 10, 2007 | HP iPAQ H4150 Pocket PC
Ipaq won't recognise sd cards help!!
did you install the following: "iPAQ H3970/H3975 SD Card Driver Updates version 1.1 (27 Oct 03)" SP25681 - Resolves performance issues with SD memory card. - Resolves undetected SD memory card. - Resolves lockups due to SD memory card.
Sep 14, 2005 | Compaq iPAQ H3970 Pocket PC
SD card failure...Help!
Have you tried resetting the iPAQ? I would remove the SD card and perform a soft reset (the little hole on the bottom) then re-insert the SD card and see if it detects. Give it a try and let me know what happens.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ rx1950 Pocket PC Logo
278 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
