Question about Frigidaire GLTF2940E Front Load Washer
Will not start
My machine will not start. The lights come on and you can hear the door lock, but that's it.
    Genius:
  • 1,019 Answers
close the door, gently turn the timer switch, to see if it starts in any position.
If this fails, the problem may lie with a faulty door/switch/sensor.
Mike @ Compurepair.
Posted on Feb 25, 2008
Have replaced door seal in creda w220wv and door light flashing, will not start
Must have disconnected the wires to the lock switch or damaged it it is situated near the door seal to the right were the door locks you can fixet from the top cover once taken off hope this helps you can also test it by inserting a screwdriver small dimention once inserted you shoul hear a clicking sound by pressing it start program and the light should go off if it does not then the result is damaged or you have accidentally disconnected the wires fro it.
Mar 06, 2016 | Creda Washing Machines
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Sep 28, 2015 | Whirlpool Washing Machines
Candy Go482 wash machine will not start its cycle.door security light flashing but no obstruction
It could be a bad door lock switch. I had taken my machine apart to clean the boot and accidentally dislodged one of the plugs (there were 3 on the mechanism) on the door lock mechanism. I got the same actions from my machine as you are. Since you probably haven't taken anything apart, a bad switching mechanism can cause the same problems.
Aug 25, 2015 | Washing Machines
Why does my Maytag Neptune washer door stays locked after cycle is complete.
sounds like the locker servo is having an issue there and may need replacement contact Maytag for a replacement part
Aug 22, 2017 | Washing Machines
2009 frigidaire front loader when push start the pause or err light come on and won't start
it may be a faulty door switch. and the door is not locking. should hear a click when the power is turn'd on and the door should not be able to open. could be the lock on the door or the switch or even the freeder for the door lock.
Oct 05, 2013 | Washing Machines
It won't start. The panel lights up, but nothing
Either the door switch or timers is faulty. I would test with ohmmeter, voltmeter, or a multi-tester that has both.
Sep 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Ge wssh300 will not start may, just beeps
hold the start and select button in for about 30 seconds together until you hear a beep; this resets the control panel
Aug 04, 2009 | General Electric WSSH300G Front Load...
Door light flashes 4 times and can hear 4 clunks?
First measure the door lock, make sure it's fine, then ensure that there's current flowing towards the door lock. if it'll trip all the electricity out you'll need to ru very close inspection or to replace the main circuitboard
Update me about your progress
Jul 24, 2009 | Washing Machines
Door won't open and no error lights
sounds like the door interlock is manfunctioning.
Jan 19, 2008 | Zanussi FJS1225W Front Load Washer
Door locking
This could be a fualty door inter lock.. easily repalaced...
Nov 24, 2007 | Zanussi FJ1454W Front Load Washer
Open Questions:
Frigidaire GLTF2940E Front Load Washer Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
