Question about MSI 845GE Max-L (MS-6580-060) Motherboard
MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
I need to know the cpu jumper settings for my motherboard.
MSI 845GE MAX L MOTHERBOARD (601-6580-060)
i have read the manual but it doesnt show any jumpers for the motherboard cpu.
Is this a plug and play cpu motherboard or do i need to set jumpers on the motherboard.
Im afraid to do anything without knowing.
the processor i am going to use is this one if this helps any.-
P42530B478 -- Intel Pentium 4 2.53GHz 533MHz 512KB Socket 478
Please email me with any help. Thank you
LUCASDC44@MSN.COM
  • lucasdc44 Feb 26, 2008
    Thanks for the answer. i greatly apprecite it.
    Can you also tell me if this memory is compatable with my processor and motherboard.
    Motherboard MSI 845GE MAX L
    processor-Pentium 4 2.53GHz 533MHz 512KB Socket 478
    memory-1024DDR2700-INF-N -- Infineon 1GB DDR RAM PC2700 184-Pin
    The manual says it takes up to 2 gb of 184 pin ddr memory.
    Genius:
  • 1,226 Answers
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Posted on Feb 26, 2008
I can solve motherboard connecting and setting pls solve can tell
Posted on Dec 23, 2008
Were can i get a manual for jumper settings
Dear,
you don't need to find out manual for jumper setting any where if you see the mother board very closely near which Jumper want to setup you can see the printed jumper setting on mother board only,
Thanks with Regad,
Ankur Goyal
Sep 10, 2015 | MSI Ms-7104 Pm8m-v Via Socket 478 Intel...
Don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
I just bought a used (or refurbished) MSI 845GE MAX MOTHERBOARD (478 pin, etc) and plugged in my Radeon 9550XL AGP 8x (4x compatible) card, (2) 512MB Sticks of Mushkin DDR2 (PC3200) RAM, Random IED HD, DVD...
Did you try another graphics card? If this motherboard does not have onboard graphics then try another card. AGP slots go bad sometimes too. I've had that happen.
Sep 18, 2009 | MSI 845GE Max-L Motherboard
Reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Aug 15, 2009 | MSI Computers & Internet
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
I need the setup diagram for a MSI K9N6SGM V2 #MS-7309 MB
Hi James,
As I can see here that you need the jumper setting specifications for your motherboard K9N6SGM V2 #MS-7309 with a single IDE port.
Even this is for version 1 the layout for the Jumper settings are still the same with your version 2 motherboard the only differences with version to are the changes on the support and bios version
Link:( Manual)
http://www.msi.com/index.php?func=downloadfile&dno=4212&type=manual
Jun 16, 2009 | MSI K9N6SGM-V Motherboard
SL-86SPE-L Motherboard manual and / or bios jumper settings required.
Load fail safe defaults from CMOS/ deseabled the CMOS.
OR press F5 when booting & continue.
Feb 18, 2008 | Soltek SL-86SPE2 Motherboard
MSI 845GE Max-L (MS-6580-060) Motherboard Logo
1,388 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
