1998 Chevrolet Cavalier Logo
Posted on Feb 15, 2010
How to disable/reset anti theft system on a 98 Cavalier z24
My car's anti theft system prevents me from starting my car 1 out of every 10 starts. You have to wait 10 minutes for the light to stop flashing, and then start it. Is there a way to prevent this from happening anymore?
  • robin Sep 03, 2018
    use a code reader to get any error codes. You can get one from autozone with a deposit, that you get back when you return the reader. Then using the reader erase the codes. Then turn key to on position for the 10 minute process. I hope this helps and you wont have to do this again.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6198
Points
How to get the anti-theif lightoff
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Feb 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
11740
Points
24
There is a button under the steering wheel to the right. Push it, and it will alternate between "on" and "off" mode. try starting it after doing that.
If your problem isn't from accidentally having that button engaged you could have faulty wiring in the anti-theft system, and you should definately get that looked at. It could leave you stranded one day.
Anonymous
Level 1:
  • Posted on Nov 06, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
6198
Points
Is there a way to byepass the anti theft on 2006 colorado
  • thomas_wi211
    thomas_wi211 Jan 22, 2013
    try changing your ignition to an after-market. there are theft chip in the ignition.
My anti-theft system came on and my key wouldn't come out but it would start and my windows don't roll down and my sunroof doesn't open does that have to do with the anti-theft system
When the anti-theft system in your car is activated, it is designed to prevent unauthorized access to the vehicle and protect it from theft. The specific features and functions affected by the activation of the anti-theft system can vary depending on the make and model of your car. However, here are some common ways in which the anti-theft system can impact your vehicle:
  1. Ignition Interlock: In many vehicles, the anti-theft system can prevent the engine from starting or cut off power to the ignition system. This is often the primary function of the anti-theft system to deter thieves from driving the vehicle.
  2. Key Removal: Some anti-theft systems can also lock the key in the ignition switch, making it difficult or impossible to remove the key when the system is activated.
  3. Door Locks: The anti-theft system may lock or unlock the doors automatically when it is activated. This can be intended to prevent unauthorized entry.
  4. Windows and Sunroof: In some cases, the anti-theft system can disable the power windows and sunroof to prevent someone from gaining access to the interior through these openings.
  5. Alarm Activation: If your vehicle is equipped with a security alarm system as part of the anti-theft system, it may activate the alarm if unauthorized entry is detected or if someone tries to tamper with the vehicle.
  6. Vehicle Immobilization: Some advanced anti-theft systems can immobilize the vehicle by cutting off fuel or electrical power to the engine.
If you're experiencing issues with your key not coming out, windows not rolling down, and the sunroof not opening, it's possible that these problems are related to the activation or malfunction of the anti-theft system. However, it's essential to consult your vehicle's owner's manual or contact the manufacturer or a qualified automotive technician for specific information about how your vehicle's anti-theft system operates and to diagnose and resolve the issues you're facing.
In many cases, anti-theft system problems may require specialized equipment and knowledge to diagnose and repair, so seeking professional assistance is often the best course of action.
1997 Chevy Cavalier. How do I bypass the anti-theft system forever?
Question edited for clarity and correct name of vehicle.
You can't bypass it Cherie, it involves transponder chips, receivers and the engine computer (ECM).. The anti-theft system is there to stop theft of the vehicle, basically what you are trying to do. You have to fix the system, not find a way around it. This is the reset. As long as you battery is good and fully charged, it should only need doing once.
Just leave the key in the run position and the "Theft System " light on the dash will be flashing. Leave the key on for about 10 minutes and the light will stop flashing and go on solid. Then the theft system is disable.
how to over-ride anti-theft so car will start? (Chevrolet Cavalier)
https://www.google.com/search?q=chevy+cavalier+theft+system+bypass
1helpful
Disable anti-theft system 98 ford explorer
The key has the chip for the anti-theft--may not be the anti-theft.
TDC/Firing Order/fuel/spark/compression/timing chain alignment (dots)
TPS (Throttle position sensor) - Bypass by holding gas pedal down and starting.
Hope this helps--
3helpful
2answers
Car will not start
You probably can't.
If the anti-theft module is in the cluster, you would need the correct key chip for the car the cluster came out of.
You might be able to bypass the passkey system by running a wire to the fuel pump relay and other components.
You may need a shop manual to find the circuits.
5helpful
My 98 cavalier starts for one second then shuts off flashs the antitheft light
to reset anti theft system--turn key on engine off, for about 10 minutes. after 10 minutes, turn key off, wait 15 seconds, then try to start car. from 97-2005 gms have a theft system called a passlock system. you can go to tubesound.com/passlocksystem. to disable system for good.
3helpful
2answers
No start cranks but does not fire has spark. has fuel if bypassed by relay fuses good new fuel pump a year ago has fuel replaced battery froze, has prostart remote start, been in 8 years no issues 2000...
check to see if the security light or anti theft light flashes. if that is the case, sounds like the bypass for the remote starter may be causeing the no start by tripping the anti theft system. Remove remote starter and bypass system and join any cut wires back together that may be cut for remote starter. Try starting, if theft light still flashes leave key in the on position after attempted start for 15 minutes till theft light goes solid, turn off and try again. Repeat process for three times to re-learn factory theft system in vehicle. If problem still persists, then take to your local dealer to reprogram factory theft module in the cluster.
Hesitation in starting and getting worse
if others dont know about it it could prevent the theft of your vehicle...it might not be a bad idea to leave it alone casue theres no telling what it would tkae to disable it and getting into your wiring could create more issues than just disabling the anti theft system
1helpful
1996 CHEVROLET CAVALIER.
It is probably not the anti theft system if it cranks over fast then slow it is your timing chain. If you want to try resetting the anti theft system disconnect the battery cables for 24 hours and reconnect them.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
