Question about Sony RDR-VX515 DVD Recorder/VCR
No Title List Found
I recorded a VHS tape video and audio to a DVD-R disc and finalized it. Now I can't play it back. I get the message "No Title List Found".
philipp
  • 217 Answers
SOURCE: Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Posted on Aug 23, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
pazman
  • 81 Answers
SOURCE: Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Posted on Apr 05, 2008
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
otacon
  • 1944 Answers
SOURCE: Can't play finalized DVDs dubbed from VHS on other Sony DVD players or PC
It sounds like the disc were not finalized properly. Are you sure the player finalized the discs?
Posted on Apr 08, 2008
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Feb 11, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I cannot finalize it keeps on saying no title list.
Are you absolutely sure there are recordings on that disc?The message means the recorder can´t find any. If you have a chance and it´s a VR-disc, try playing it on another player that is known to be able to play unfinalized VRs. If it was recorded in video mode there´s nothing you can do. If the material is of great importance turn to data retrieval professionals.
Dec 12, 2008 | Samsung DVDR120 DVD Recorder
Burn dvd from vhs
i'm assuming you have a vcr to play your vhs tapes, just plug your audio/video cord from your vcr(out), plug into the audio/video vc10(in), start playing vcr and press rec botton whenever you want to start to record. make sure you can only use dvd+r. choose the quality for the length of time, at the end press 'function' to finalize the disc, then you are done.
Sep 06, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Finalizing DVD
If the size of the vhs recording was in 2hr mode, and the size of the recording itself is about 2 hrs, you may not have enough space to finalize. I would use your PC to finalize the disc - I use Dr. Divx, but you can find many finalizing programs out there.
Sep 04, 2008 | Zenith XBR413 DVD Recorder
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
Sorry.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Disc Finalize stuck at 99%
press OK button on the remote of the DVD to take finalize 99% off the screen , then EXIT button
Mar 01, 2008 | RCA DRC8335
Finalizing dvd
VHS tape to a DVD-R
Jan 13, 2008 | Zenith XBR413 DVD Recorder
Sony RDR-VX515 DVD Recorder/VCR Logo
274 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
