Question about Casio KL 750 Thermal Printer
Cutter Cartridge I want to buy a cutter cartridge. Can't seem to find one.
  • Frankies Feb 26, 2008
    Just waiting
  • fl2tburt Aug 05, 2008
    trying to locate cutter cartridges, have two of the KL-750 thermal printers.
A tape cutter cassette (cartridge) for the Casio KL750B label maker may be purchased only from the Casio parts department. It is part number "TN1". Call 1-800-223-2001, hours are M-F, 9-5, Eastern time. Cost as of today is $3.50 + 4.95 S&H + applicable tax. They are on back order 3-5 weeks.
Hope this helps.
Posted on Mar 12, 2009
Found One--Casio.com
Posted on Feb 29, 2008
How to remove rubber seals from inside moen 1225 faucet body
Make a cutter from the old cartridge. Cut some slots in the base that normally sits on the seal. Use a hacksaw or grinderette.
Clean up with a file to prevent damage to the sealing face. Insert the old cartridge back and give it a few gentle turns with minimum pressure. Remove 'cutter' and flush out debris.
Oct 26, 2017 | Home
Can I replace just the blade on my pizza cutter? It seems a shame to buy a new one as it really is in good condition, just the blade is blunt.
The Web Restaurant Store sells pizza cutter blades for a good price, although as the pizza cutters themselves are not expensive, you might find it just easier to buy a new one.
http://www.webstaurantstore.com/american-metalcraft-pcw-4-4-pizza-cutter-replacement-blade/69332864.html
Feb 28, 2013 | Home
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
Cutmaster 81 plasma cutter when turned on, starts normal but air solenoid keeps going on and off. What could be the problem?
Hi:
Sound like you have a faulty start cartridge, probably you used the torch handle to bang a metal part to make it fall. This is a common problem when using the gun as a hammer. Just replace the start cartridge. Before changing it; check the cartridge's lower end, this must move freely up and down.. If you did replace the cartridge already then probably your output power pc board it's damaged.
Regards,
Jun 23, 2011 | Miller Welding Tools
My Thermal Dynamic Drag Gun Plasma Cutter runs but cant blow its arc. Bit of spark, Bit of air, then just refuses to blow its arc. Was working well and with new tips and electrodes but then just refused....
Hi:
There is no mention of the Thermal Dynamic's gun model, but i will suppose that it is a SL60 or a SL100 which are replacement guns for any model of plasma using the proper adaptor.
Your problem could be the start cartridge which go bad now and then when the gun is used as a replacement of a hammer to make the cut piece to fall.
The way to check if your start cartridge is in good condition is by checking the low part of the cartridge, push it up (or down depending on the way you handle it) it should freely slide inside and return out.
Good luck.
Jun 16, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
May 29, 2010 | Braun 360┬░ Complete Electric Shaver
Printer won't recognize brand new color cartridge
According to the Dell website, this is how the cartridges for the Dell All-In-One Printer/Copier/Scanner Model AIO A940/A960 are supposed to look like. (see attachments)
Black cartridge P/N: 7Y743 with U-shaped "lump" on the (black) lid. (equivalent to Lexmark "82")
Color cartridge P/N: 7Y745 with square with corner cutout "lump" on the (blue) lid. (equivalent to Lexmark "83")
BUT, the black Dell cartridges have the identical corner cutout "lump" as their color cartridges. In other words, they have the lid from the color cartridge, but in black instead of blue.
Both cartridges are made by Lexmark and rebranded for Dell. But Dell made the black cartridge intentionally with a different "lump", so customers are forced to buy expensive Dell cartridges.
Stupid actually, because now the black and the color cartridges each fit in the other's slot!
Beat Dell at their own game, don't pay their rip-off prices!
When you open that Dell printer, lift the black lever that closes over the black cartridge. From the underside of that lever you will see a small "pin" sticking out, that corresponds with the corner cutout "lump" (as depicted on the color-cartridge). Cut that pin off with a sharp knife or a wire cutter.
All of a sudden, the cheaper Lexmark "82" black cartridges fit in (and any other remanufactured equivalent).
Money in your pocket!
May 12, 2010 | Dell 944 All-In-One InkJet Printer
The thermal transfer paper tore during process how do I fix it? I removed the cartridge but now the fax paper just sit in tray while the rollers rolls.
Cartridge? There is no print cartridge in a thermal fax. Maybe you removed the thermal print head. Put it back! You simply need to "thread" the fax paper back through the slot that leads to the cutter mechanism. When you close the lid the rollers will pick up the paper and cut off a fresh strip. Locate the long slot for the paper.
Jul 22, 2009 | Brother Office Equipment & Supplies
Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
Sep 02, 2007 | Braun Syncro 7526 Electric Shaver
Casio KL 750 Thermal Printer Logo
595 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
