Question about HP Pavilion dv4000 Notebook
Hp 4600 laptop
Pressing the power causes a few lights to flash on but never powers up.
  • 1 more comment
  • fox733 Feb 26, 2008
    New Battery power soure is good the computer never boots up,lites just flash
  • fox733 Mar 01, 2008
    Power source is not the issue.
  • fox733 Mar 02, 2008
    The lites flash for a couple of seconds,nothing spins, no cds in drive,no attempt for screen to go on,no beeps
Did you here any beep sound when on the system. If beep sound is came means check your ram.
Check weather any driver is connected & (cd or dvd) is in the system. Remove that. Now restart it.
Posted on Mar 01, 2008
  • 520 Answers
Usually if there are problems you hear a number of beeps.
remove power cable , remove battery.insert power cable and try to boot if ok put the battery back in see what happens.chances are itll start to recharge if not you know its your battery faulty
  • 1 more comment
  • tat4u
    tat4u Mar 01, 2008
    need more info.you turn on lights flash ? then what?
    have you a cd in the drive and can you hear it spin.
    can you hear the fan start.
    can yo hear your hd trying to do something.
    do you have a black screen or does screen not even attempt to come on.
    are there any beeps at all.
    what lights flash and for how long
  • tat4u
    tat4u Mar 02, 2008
    first off find location of rtc and remove battery for a few minutes then replace.
    if its a bios problem this will resolve that.
    check hard drive.remove and replace make sure housed properly;(when u start up if you listen carefully u can hear your hard drive doing something,if you can hear repetitive clicking your hard drive is damaaged,there should be a kight to indicate that the hard drive is accessed also,if no lights no sound then its a motherboard component problem.
    check memory cards,remove /replace.if theres no memory present,or damaged you will get a blank screen(nothing,as if you havent even turned pc on)
    if the pc has been dropped check graphics card .if the graphics card is missing dislodged or damaged you will also get nothing on screen.if this is a second hand pc youve purchased check if speakers are connected(possible reason for no beeps)
  • tat4u
    tat4u Mar 02, 2008
    oh forgot...rtc is on motherboard ,you dont need to remove it just remove battery next to it (looks like a large watch battery,silver)
    make sure a os disk in drive.if you cant hear any response from cd,hard drive or fan you have power failure on motherboard.
    Sergeant:
    Champion:
  • 310 Answers
Check your battery.
Posted on Feb 25, 2008
  • khader ibrahim Mar 03, 2008
    Check the fan is running.If it working means their is a problem in your ram.
    Did you install any software or you remove any software?
Hp probook 4510 not powering up (orange light flashes a few times when power button is pressed
Disconnect power adapter.
Remove the battery
hold down power button 10 seconds
plug in Power adapter
press Power on
Aug 08, 2016 | HP ProBook Computers & Internet
Hp 250 g1 laptop when pressing power button it flashes green but will not power on
If the light is flashing with a descernable pause, you should count the number of flashes. A search on the net should then identify what the flash sequence means, and whether or not the machine can be repaired.
Apr 07, 2014 | Office Equipment & Supplies
The power cord light flickers and when pressing power button power symbol lights and goes out.
This indicates one of your charger, battery or power cord damaged, just check laptop is getting power or not,
probably this may be causes by defective charger or power cord,
Thank you,
please rate me if you are happy with this..
Sep 04, 2011 | HP CompaqPresario CQ61310USE Notebook
I have an intermittent power-on issue with my Dell E4200. Sometimes it is very hard to turn on - pressing the power button makes the button light up, the fan runs for a few seconds, then the caps lock icon...
Try performing a hard reset on the laptop. Remove the battery and all peripherals connected to the laptop (including the AC adapter). Once everything is removed/disconnected, press and hold the power button for around 15 seconds. This will drain all remaining charge in the motherboards capacitors which usually causes this kind of issue.
Hope this help. Goodluck!
Mar 28, 2011 | Dell Latitude E4200 Notebook
4600 Sluggish Boot Up
sounds to me like a failing psu, you may need to test it with a psu tester if you have one available, if not any local pc repair shop should have one
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Oct 31, 2009 | Dell Dimension 4600 PC Desktop
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Green led mains light comes on, battery amber light rapid flash
This sounds sucky, but you may have a power-supply issue. Especially if you have had to repeatedly press the power-button. If the laptop is new, call Toshiba and see if it's under warranty. If not, find a local computer tech to test your power-supply. This problem is less common nowadays, but still an issue for some!
Hope this helps!
-- RT
Aug 26, 2009 | Toshiba Satellite Pro 4600 Notebook
Hp 4600 laptop
hmmm...try it with the battery removed only on AC power..
Feb 28, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv4000 Notebook Logo
430 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
