Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
I have it twice and the sound starts sounding bad...(Base)
This is my second one, and the same problem has occurred. You want to listen to it, but your base starts sounding weird. I thought it was my headphones, but I tried different ones and the it still sounds as if the speaker is bursted... and with each sansa c40 I have had less than a month and a problem occurs less than a month...I'm tied of getting another one...It would look really dumb to get a third one...I HATE DEM..!!!!! The manufacturing has gone really bad for you to have problems with them less than a month..
    Problem Solver:
  • 44 Answers
Might be your music EQ. can make your music sound really weird.
Posted on May 22, 2008
My Mazda 1989 cut out when I accelerated I don't think the car was heated up properly as it's carbureted , it turns over but the engine doesn't start
This sounds like a fuel delivery problem, but to be sure, try some Spray Start following the instructions on the can and see if it tries to start. If so, you have eliminated the ignition as being the culprit.
Not knowing the size motor or model of your car, I would hazard a guess that it is going to be either a bad fuel pump, or a clogged fuel filter. While observing safety try and find the schrader valve on the fuel rail that feeds each injector, (looks like a tire valve stem only all metal) and depress the center post. Fuel should squirt out with about 40-50 pounds of pressure. Cycle the iginition key and listen carefully for a faint humming sound lasting only a second or two. If neither fuel at the fuel rail or sound is heard, I would suspect a bad fuel pump. If both are present, then look for other problems. Since this occurred while it was running and under acceleration, it is possible that it jumped timing, blew a head gasket, or a myriad of other possibilities. Always start with the easy/cheap stuff first.
Good Luck.
Jul 11, 2014 | Cars & Trucks
WHat are some symptoms of a Subaru legacy fuel pump
The car won't start.
Lift up the rear back seat base cushion.
Turn the ignition on and listen for the fuel pump operation under the seat. If you hear no sound, then pull off the inspection panel there, and remove the fuel pump. Replace it, and retry.
This occurs on the Legacy from time to time, and I've replaced a few.
Nov 12, 2012 | Cars & Trucks
Starting problem think it is fuel filter but not sure have blown filter out twice but problem keeps occuring would it be the pump? once it starts it runs well. Its a mitsubishi triton dual cab ute mk 2003...
Thanks for choosing FixYa and welcome to the site. Listen to hear if you can hear the fuel pump kicking on when you first turn the key. You should hear a humming sound for a second or two. If you do, it is working, If not, it is not working. If so, check your fuel pump fuse, relay, and shut off button if you have one. It could also be bad fuel injectors. You can pour fuel into the intake, if it starts, you have a fuel issue. If it doesn't, it shouldn't be fuel related then. If these all check out, if you don't have inside power, it is a connection problem with the battery or a bad battery. If you have power and there is a clicking sound, clean the battery terminals and post, check the connection. Make sure the battery is good. If you turn the key and there is nothing, you have a bad starter or starter solenoid. Check your ignition fuse also. If the starter is not getting the correct amount of power from the battery, it won't start. Make sure the alternator isn't draining the battery as well.
Aug 21, 2011 | Mitsubishi Pickup Cars & Trucks
Hi, I have Bose in-ear headphones and the sound is really bad on them since last night. It sounds like the music is really far away and without any base. I can only feintly hear the singer and one...
It sounds like you have a faulty connection between the headphones and the music device. Try fiddling with the port of your computer, iPod, or whatever else you use to listen to music. If the headphones do this on more than one device, it's a problem with them. Fiddle with the cord while you listen and see if you can target the bad area of the cord. If you can manage to listen to the headphones successfully while tweaking the cord, you might be able to use them still, if not they're probably blown or dead. Hope this helps =]
Mar 03, 2011 | Bose in-ear headphones - Black with...
Starter turns, battery is good but car won't start. Think that there is no fuel delivery.
turn the key over,but not to the start position,when you do this listen for a whirring sound from the rear of your car. this will be the fuel pump powering up. the sound only lasts about 2-3 seconds.if you dont hear this,then the fuel pump is bad. if you do hear it and still no start,then the ECM is bad.
Apr 29, 2010 | 1995 Honda Civic
In my 2004 Trailblazer a clicking noise starts about 1 minute after the car has been started and then the clicking continues for about 90 seconds. The clicking is audible from the inside and outside but is...
I should guess it to be the electric fuel pump, although I thought those sounds had been eliminated by the manufacturers long ago. Perhaps you could raise the car in the air and get underneath it and see ( or I should say "hear")
That sound from the fuel pump should not mean it is bad or is going bad.
God bless your efforts.
Oct 17, 2017 | 2004 Chevrolet TrailBlazer
Truck starts low idle about 500rpm, sputters then
Does it do this on warm restarts or on cold starts? Have you checked fuel pressure? It sounds like a bad pump, but I would try the filter first.
Aug 22, 2009 | 1999 Chevrolet K1500
Roaring sound from under hood; 1995 740I
if this car is turbo most likely early signs of turbo failure or reconditioning oil runs threw this turbo letting the sound out threw the exhaust turbo is mounted pass side lower exhaust area
Sep 11, 2008 | 1995 BMW 7 Series
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
