Question about Canon imageRUNNER C3200 Copier
Error Code E000020-0225
Hello All,
I started of with the error code E000020-0181, I went ahead and replaced the Yellow toner as described on this site.
I then got an error code E000020-125, so I replaced all toners to be safe, this still didnt work. I then followed the below:
Depress the Additional Function key, then the 2 & 8 keys at the same time, and the additional function key again. This will display the service mode menu. Touch the Copier key. Across the top of the screen you should see " Function ". Touch it, look for CLEAR in the middle column. Touch it, then ERR, then OK. Turn off the copier and wait a few seconds then turn it back on and all should be well.
Now I receive error code E000020-0225, any assistance would be greatly appreciated.
Craig
  • WEDM Feb 26, 2008
    Hello Spinal,
    Thank you very much for the explanation. In our company it is very possible that this copier has done 300K ++ copies.
    One other question: If the E000020-0181is for Yellow and E000020-0225 is for Magenta I assume E000020-0125 would be either Blue or Black.
    I think I will just get the copier dude in to fix the belt, I dont want to mess around in there too much.
    Thanks again,
    Craig
  • Canon Expert
  • 287 Answers
Wedm/Craig. I will glady help you, and I am extremely confident that I am correct. More importantly I wish to to help you avoid The "COPIER DUDE COMPANY" taking a large chunk of your cash. I work for a "COPIER DUDE COMPANY" and we charge $200 just to say "yep, you have a problem". So lets start from square one and please forgive me if I get long winded and redundant. You tagged onto a request for help initiated by a customer called Brassmonkey who had a code of E000020-0181.This code means that when the copier attempted to calibrate each color (cyan,magenta,yellow and black) as it does from time to time to maintain optimum copy quality, the target values for yellow could not be achieved. Not even close. Yellow is the first color the copier checks and is used as a reference for the rest of the color calibration.Therefore it tends to be the primary error code in the event of a problem. Now here is where it gets hairy. Hang with me here. A patch of color is placed on what is called a transfer belt. This belt is where the image/copy is created prior to it being transferred to the paper. In fact, there is a point in time where the color copy you requested exists on this plastic belt, held by a staic charge, and is waiting to be pushed onto the paper as it goes through the machine. So when the copier goes thru periodic calibrations, again it makes a yellow "patch"....looks at it....... reajusts....looks at it... until it hits the optimum target of quality. And it does this for every color. So, now to the NUTS of it all. You have a drum&developer "unit" for each color.One dual unit for each. They are fed toner as they need it. Any one unit can fail due to shear normal use,and this is not a function of toner.{I have seen weird shit that defies logic before but toner is on the wierd shit list} Now, at some point the "plastic transfer belt " fails. So no matter how new the drum/developer units are, the "medium" from which the colors are being judged by cannot provide a valid measurement. Its like an old guy like me trying to read small print with scratched glasses. New text does not mean I can read it better. So now you have an 000020-0225 code. This means that the magenta color calibration failed.This tends to lean toward the transfer belt(scratched glasses) being worn. Two color calobration failures make ya wonder. Canon says that under the best of conditions the tranfer belt is good for 300K. These are all remote troubleshooting suggestions but at least you will have the benefit of these details. And the transfer belt is A: not real expensive and B: not labor intensive. I hope this helps. Good luck and take care. ............SPINAL........
Posted on Feb 26, 2008
I am getting error code E000020-0000 as soon as start my iR3530. I tried resseting the error by going to service mode menu. But still same error occurs. Any solutions?
Posted on Apr 24, 2008
Hello sir i am getting error on Canon irc3170 errror code 0020-01a8 ..... it was working fine but when i filled yellow and magenta tone since then i am getting this error code i think i ned to clean atr...
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XXA8= In ATR control, the detected T/D ratio is upper than its upper limit (13%) 3 times
in succession.
-01A8 = YELLOW ISSUE
Check on toner leak from toner buffer in the developing unit, Replace the ATR sensor
imageRUNNER C3100 / C3170
Jan 09, 2018 | Canon ImageRunner C-3170I Copier
E000020-0181
This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Feb 21, 2013 | Canon imageRUNNER C3200 Copier
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
Jan 24, 2018 | Office Equipment & Supplies
Error code E 020 0181 How do I clear error code? Cannon 1150 color laser copier
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Oct 11, 2010 | Canon CLC 1150 Color Copier
C-OF34 error code?
this error code means there is a low toner to developer ratio in the yellow developer the common causes for this problem is the pwb-mc board needs to be replaced or the yellow toner motor needs to be replaced or or the toner motor one-way gear has failed to reset the error code leave the machine on and open then close the front door if the error code comes back check and or replaced parts listed above.
Dec 02, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Oct 09, 2009 | OCE Office Equipment & Supplies
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
1,346 people viewed this question
old marine
old marine
