Fill and drain cycles work fine until the soap dispenser is triggered to open by the timer. When this happens, there is no water filling the tub and the motor seems to run until the next cycle, which then works fine.
What would cause it to skip this cycle? I think it maybe related to a contact on the timer. Any help would be appreciated.
thanks,
steve
here are a few possible causes for a dishwasher soap dispenser's trigger/spring to continuously try to open the dispenser after it has been opened:
The trigger/spring mechanism may be damaged or broken. This could be caused by normal wear and tear over time, or it could be the result of a foreign object getting stuck in the mechanism. The dishwasher's control board may be malfunctioning. If the control board is not functioning properly, it could send a signal to the soap dispenser to continuously open and close. There may be a problem with the dishwasher's timer or motor. If the timer or motor is not working properly, it could cause the soap dispenser to malfunction. To troubleshoot the problem, you could try cleaning the soap dispenser and checking for any foreign objects that may be stuck in the mechanism. You could also try resetting the dishwasher by turning off the power and unplugging it for a few minutes, then plugging it back in and turning it on. If these steps do not resolve the issue, it may be necessary to call a professional for further assistance or to consider replacing the soap dispenser.
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Hi Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser; this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is what a wax motor looks like. Please do rate the solution and revert for further assistance. Thanks Rylee
Please provide the model number and the approximate age of the dishwasher.
If this diswasher uses a turning dial to select the cycle, which turns as the dishwasher progresses, I strongly suspect that this timer has failed and needs replacement. Especially since the soap door never opens. Does the dishwasher drain during and at the end of the full cycle?
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
