Question about Car Audio & Video
Swapped out cd players now getting high pass through subs
Took out clairon cd player and installed alpine cda-9885 and now I cant get it to stop playing highs through my sub.
  • 30 Answers
This is very easy...just unplug the rca cables out of the back of the deck, and plug them into the "subwoofer" output. On some alpine decks this is on a "pigtail" wire that extends from the deck. Once this is connected to the right output, you can control the subwoofer level from the volume knob by pressing it inwards.
Also.... your amplifier should have a low pass filter, it should be on a switch marked "LPF". Make sure this is switched on.
Posted on Feb 28, 2008
Cda 9885, When in tuner mode sub does not play
Does you car volume get lower when you stop. If not sounds like an internal issue. No sound at all my brother hooked his up and when he switched to tuner everything would go through the subs but you would not know it sounded like his 6x9s no bass. was a wiring issue. I dont know if this helped or not.
Feb 28, 2014 | Alpine CDA-9885 CD Player
THE STEREO CODE FOR ASN ALPINE CDA 9855? HOW OR WHERE DO i GET IT??
there is no code for an alpine cda 9885. what seems to be the problem with the radio?
Jan 03, 2011 | Alpine CDA-9885 CD Player
My Alpine 9885 stops outputting sound to everything but the amp (and therefore sub). Turning off the deck and then powering back on seems to fix it temporarily. Any ideas what could cause this?
You have a speaker with an intermittent problem or a speaker wire shorting out. The unit has a protection circuit so it doesn't fry the amp inside
May 14, 2010 | Alpine CDA-9885 CD Player
How do i get my Alpine CDA 9885 head unit out to fit a sub???
Remove the face, and trimring plastic.
There are slots on either side that you put the Alpine unlocking keys into (came with your headunit new) then slide the chassis out.
If you don't have keys - you can use a small allen wrench - or buy them at best buy etc.
A local alpine dealer will probably let you borrow his keys as a good business practice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | Alpine CDA-9885 CD Player
Alpine CDA-9885 intermittent problems
you can try removing the faceplate and cleaning the copper contacts with a pencil eraser. This might help
Jun 15, 2009 | Alpine CDA-9885 CD Player
Manual for cda 9885 r
http://www.alpine-europe.com/index.php?id=915&L=&manualsearch=CDA-9885R
Feb 02, 2009 | Alpine CDA-9885 CD Player
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Aug 12, 2007 | Alpine CDA-9885 CD Player
Car Audio & Video Logo
152 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
