1998 Pontiac Sunfire Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1998 Sunfire 4 dr, Replaced the car battery and now the radio is locked, where can i get the code to reset it. All that happens is a red flashing light beside the power/volume nob. please help
john h
Level 3:
Top Expert:
  • Pontiac Master 29,494 Answers
  • Posted on Feb 15, 2010
john h
Pontiac Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559710
Points
193449
Dealer has codes radio "loc"is part of security system call first they can also advise how to retrieve the radio id code which is needed or if u have manual in it explains how to retrieve the radio id code
Replaced the radio in my 2001 Pontiac Sunfire with a radio from a scrapped 2001 Grand Am. Radio says "locked". How do I get it to work?.
Because you have removed the radio from a power source it automatically goes into stolen mode making the radio useless when stolen. This mode is selected when you change the battery but in that case you would have access to the code to re-enter it. Talk with a radio tech and they may be able to say how to fix or where to go to get the code.
Lost all power to my 1997 Pontiac Sunfire.
Have the battery tested but feel you may have found the problem.
Installed ignition on 2003 sunfire, how do i reset security system
did you reuse the same pass lock sensor and key lock tumbler? if so the security system shouldn't have to be reset. if you replaced either lock cylinder or pass lock sensor then you have to turn the key to the start position and then to the run position and leave the key on for about ten minutes and wait for the security light to stop flashing. once the light stops flashing do the same process again. it may take up to three times to get the key code encrypted into the BCM. on the third time after the light stops flashing the car should start, if not then you may have another problem.
3helpful
How do I reset the service engine light on 02 pontiac sunfire 2.2 engine?
Best option is a scan tool or code reader.Alternatively you can disconnect the battery but if you have theft lock on your radio you may need to get the code to reactivate it.
Can't remember radio unlock code
Dealer can reset this for you, for a fee of course.
1helpful
Unlock radio code
the radio station buttons numbered 1 2 3 4 5 6. enter the 5 digit radio code there. if it locks up or goes to error you must remove the negative (-) battery cable to reset the radio and try again. it will let you try 3 times.
Cannot use radio after battery change, I have the code,not workin
you can only try the code install 3 times before the radio locks up.
you will have to disconnect the battery for 10 seconds if that happens. the 5 digit code gets entered where the station select buttons are 1 2 3 4 5 6 enter the code there.
2answers
Radio reset
go ther dealer or buy another radio
Resseting alarm lockout in 2001 Pontiac Sunfire
turning left and stalling sounds like your power steering pressure switch is bad.as for other problem try unlocking drivers door using the key this should reset the factory alarm. also make sure you didn't miss a wire when reconnecting bat. look for 12gauge red wire near bat. this goes to computer if not connected car will crank but not start.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
