Question about Aprilaire 700 Humidifier
Water leaking from the bottom of the humidifier
Whaatever i did, water still leaking at the bottom of the humidifier
  • Anonymous Nov 28, 2008
    My humidifier is a small one but, for some reason it is running and not blowing out the humidification. At the bottom there is an opening that says nit to operate while running faucet water. Does this mean that I should run water in this opening and do not operate it while doing so?
  • Gary Davd
    Gary Davd May 11, 2010
    is the drian clogged it is suppose to run water out the bottom drain tube
  • 30 Answers
Make sure the bottom port on the humidifier is seated properly in drain port. Make sure your drain line is not obstructed.
Posted on Mar 04, 2008
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
My generalaire humidifier leak from the bottom , I have check the hose and inside all ok
Did you check the orifice inside the supply water tube? Sometimes the orifice can come loose and allow to much water inside the humidifier.
Feb 06, 2014 | General Filters 1099-LH Humidifier
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
Water leaking from bottom of 550 aprilair humidifer
Hi they should be a hose going to a drain in the floor there are insrtuctions on the wed just google the make and model and you can down load them
Dec 28, 2009 | Aprilaire 550 Humidifier
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Humidifier leaks
My Air-O-Swiss U7142 has a leak from the very bottom. I found that as long as the water flows on to the "pan" that evaporizes the water, the water will come out from the bottom. Does anybody know how to fix this?
Jan 18, 2006 | Honeywell HCM530 Humidifier
Aprilaire 700 Humidifier Logo
631 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
1STHVACMAN
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
