Question about Areca ARC-1210 Serial ATA Controller
Ram memory upgrade
I have an old DELL DEMENTION 3000. I WANT TO KNOW THE MAX RAM I CAN INSTALL TO UPGRADE THE SPEED.
  • 50 Answers
  • 44 Answers
1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
Posted on Feb 25, 2008
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Maximum Supportable RAM size per slot in Dell N4010
go to crucial memory and download their memory scanner. it will tell you how much memory is installed and what the max is per slot on any computer. hope this helps
Jun 24, 2013 | Dell Inspiron N4010 Notebook
I have a ACEer 5315 model no ICL50 running Windows Vista. To say Vista is **** is an understatement. I want to switch to Windows 7 but guess I will need a lot more RAM for this. Can I upgrade Ram on this...
I recommend that you switch to Windows 7 without upgrading your RAM. Windows 7 is a lot faster, better and uses less RAM than Vista. Recommended RAM for running Windows 7 is 1GB but I have installed them on a Centrino 1.5GHz with 768Mb of RAM and they run perfectly.
So make the upgrade to Windows 7 anyway and if you feel that you need more power then you can get more RAM.
Also, download Windows 7 upgrade advisor to check if your pc is compatible. Download upgrade advisor here.
Feb 06, 2010 | Acer Aspire 5315 Notebook
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
I have a dell dimension 3000 and i want to upgrade ram
Best thing to do is to go to www.crucial.com and run their system scan. It will tell you how much you have, how much it will hold, and what kind of RAM you need.
Thanks for using Fixya.
Oct 14, 2009 | Dell Dimension 3000 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
DELL OPTIPLES GX280 (E219542) MOBO, MID TOWER
Several long beeps means there is a problem with the memory. First of all make sure the memory is seated in the slot perfectly. There should be no movement whatsoever when you gently try to rock it side to side. If it still persists the bad news is the memory is most likely shorted out or defective. They are VERY sensitive to static electricity. I would go ahead and put the old memory back in for now and send the new defective memory back. Most vendors will issue you a replacement free of charge if you let them know it's not working.
Hope this helps!
Mar 05, 2009 | Dell Optiplex GX280 (99301) Motherboard
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
Memory upgrade
hi there, if is still hardware warranty, don't touch it. use your warranty. better to repalce unit with warranty. Beeping sound means memory problem. The problem is in the slot of the memory chips of the board. If the warranty laft, try to clean the slot of the memory chips to the board and the contact of memory chips. It will work seem you were using it before you upgrade the memory. TY
Dec 22, 2007 | Dell Dimension 3000 PC Desktop
Areca ARC-1210 Serial ATA Controller Logo
235 people viewed this question
Top Areca Computers & Internet Experts
David Payne
David Payne
Are you an Areca Computer and Internet Expert? Answer questions, earn points and help others
