Question about Minolta Dynax 505 35mm SLR Camera
Bat indicator blink´s
The machine don´t torn on as the bat indicator bilk´s even with new bat´s
    Master:
  • 619 Answers
Hi , clean the battery terminal having acid rust to contact will positive and nigative terminal.Open the lense to release the shutter miror might open , check the camera option select in auto or manual not in lower speed can cause stuck.open the film compartment and load film .
Posted on Feb 28, 2008
My proofcam wont take pictures, new bats red light stays on doesn't blink like other one does. Help
Have you tried swapping/exchanging batteries with those that works; maybe you should try this option first and see what happens.
Chances are your new battery is defective or that your camera needs to be serviced or repaired (motherboard defective/component failure)
Red light indicates low/drained/incompatible battery; as such no pictures will be taken/captured
Oct 12, 2017 | Televison & Video
My moto g Is stuck in safe mode and has a cyber net warning saying we owe $300.00 fine . can someone help me?
Sounds like you have mal ware on your machine. Many of these claim that you have done something wrong (usually porn, but I\'ve seen them claiming I drove through a toll road without paying, even though we don\'t have toll roads!) It\'s trying to bilk you out of money. I\'m not sure what OS you have, but you might have to back it to the latest safe point. In the installation there is a mechanism to let you set a checkpoint, that if something fails, you can reset it to that point. It usually involves loss of data. If this is a browser, sometimes you can use switches on the command line to make it not load all sites. Worst case if it\'s a browser, take the machine off line and see if it will boot. If you can find the stored page delete it. Since I don\'t know which browser you use or any other information I can\'t give you any more details. DON"T PAY THE MONEY!!!
Jack
Aug 06, 2014 | Computers & Internet
Tv on after same time tv off red led bilke 6time
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 12, 2014 | Sony BRAVIA KLV-37S310A LCD TV
Why did the guy at the store tell me not to use my new bat at the batting cages?
It's not a good idea to use a new, quality baseball bat at a batting cage because the balls that come out of the machine are much denser than regular baseballs. This could end up doing irreversible damage to your baseball bat.
Jan 14, 2013 | Baseball & Softball
How to join two pieces of batting that was torn without leaving a lump
Put your batting side by side evenly. Do not stack on top of each other. Use the longest and widest zig zag stitch you have on your machine. You will be ziging on one side and the zag will go over to the other side. I have done this many times and have had no problems. Hope this helps
Jul 23, 2012 | Sewing Machines
My signal lights don't work on my 99 nissan Maxima
If neither your left or your right turn signals work, then it's most likely your electronic flasher unit that has gone bad. It's located under your dash near your steering column and will be labeled
Oct 13, 2009 | 2000 Nissan Maxima
FAILED FRONT RH INDICATOR
Simple, it just means that one of the right hand flasher bulbs, either back center or front, is burnt out. If all the bulbs are ok, there is probably still one not flashig because of faulty wiring or something in the same line like a switch malfunction or in newer technology, onboard computer malfunction. Being a jaguar, if the bulbs are all OK and you still got a problem, i'd suggest having it checked by the dealer.
Jul 07, 2009 | 2000 Jaguar S-Type
Minolta Dynax 505 35mm SLR Camera Logo
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
