Sony Playstation 3 (PS3) Console Logo
Posted on Feb 15, 2010
My game remote red light stays on but doesn't
My game remote red light stays on but doesn't work with my system. Worked earlier but nothing now.
Anonymous
Level 1:
  • Contributor 53 Answers
  • Posted on Feb 15, 2010
Anonymous
Contributor
Level 1:
Answers
53
Questions
0
Helped
10702
Points
74
Try puting the charger in it and press the ps button if that doesnt work restart the system.
What is the red light in the middle of the speedo?
the red light is to a alarm system you may have or may not it stays on all the time when you do not have the system i have not worked on a pt with the factory system so this is all i can tell you do not worry it means nothing , but it dose stay on larry
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
1helpful
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
6helpful
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
1helpful
Wii remote not working, no lights nothing, new
have you tryed to resync the remote if not i ll tell you how to do that
first of all you need to open the little door on the wii console cause theres a red button behind it
then open the back of the wii remotes and there should be a little red button with sync written underneath
then hold both red buttons for a few seconds untill they both sync up cause the light on the bottom will contiunely stay litten
54helpful
3answers
Wii remote lights blink but it doesn't turn on or work
Turn The System on and open the slot next to the disk tray Then press the red button after that open the battery.Don't take the batterys out but press the red button next to the batterys.That will get you syncronized and you wiil never have to connect the remotes the old fashion way.Just press 1 and 2 when the console turns on and you wil be ready to play.
3helpful
PS3 won't stay powered up.
powersupply is bad. ebay has them for around 45.
Wii broken?
replace the batteries, and or try a friends remote.
PS3 locks up when I try to load a PS2 game
If you have a 40GB it has absolutely NO backwards compadability with PS2.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
