Question about Canon NP 6050 Copier
Roller skin come off and toner sticking to it.
Hi, I have a Canon 6050 and if i describe where the roller is you'll know which one I'm talking about.
Open front door and pull out 1st drawer and under the yellow cover there is a roller that heats up. This roller has a damaged skin and the toner is sticking to it.
Where can I get one of these rollers and how easy is it to fit.
Malcolm
North Scotland.
    Sergeant:
    Champion:
  • 317 Answers
You are talking about the Fuser, you can do any of the following:
1) Buy it online from ebay or directly from canon.com
2) Order it at your local computer supply shop.
The part you are looking for is:
http://www.copiersupplystore.com/ProductDetail/CANON/UFR601.aspx?utm_source=Shopping&utm_medium=cpc&utm_campaign=Shopping
Hope that helps!
Posted on Feb 25, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
What is the problem when my canon ir-2016 says out of tonner
magnet roller poor contact on roller bush connector... other wise roller blade ya roller stick clean properly Nd cheek board connector.. otherwise the magnet roller is damaged... clean the full toner unit...
Aug 01, 2014 | Canon iR 2016i Black and White Copier
Gears breack more and more time of heating unit in 6050
check the heater roller bearings it may have jammed or one of the gears may have jammed, replace faulty part. if gears worn out due to overheating, replace the thermistor.
Jan 10, 2011 | Canon NP 6050 Copier
Why replace cleaning web roller?
Because the web moves just a little bit each time the copier makes a copy. The reason for the web is to clean off the upper fuser roller and it also applies oil to the roller so that the toner will not stick to the roller. If you do not want to replace the web, reset the counter & move the web lever out of the sensor & make your copies. In a few days or weeks you will need to replace the UFR & web & web sponge roller... Good Luck
Oct 05, 2010 | Canon NP 6050 Copier
Blank copy just plain white paper
toner, charge or dev not in position or of cause we could go for upside down original, my guess toner 75% Carona/charge roller 20%, 4% Dev unit outa position, 1% blank original.....hows that for 20 years summed up on white paper;)
Nov 04, 2009 | Canon NP 6050 Copier
Canon ImageRunner 2800 toner buildup
YES this parts is for cleaning purposes to collect toner that was building on the pressure roller .replacement of this assembly is needed if thick toner waste accumulates on the roller
Jul 16, 2009 | Canon Office Equipment & Supplies
E37 code on a kodak image soucre 50 copier/similar to canon 6050
Kodak E37 = Canon E0005
Its Mean The Web Roller Is Over
Replace The web IN heater Roller Or Clean The Web Sensor.
Mar 09, 2009 | Canon NP 6050 Copier
Duplex does not work
you must change fixing roller and the web (it cleans the fixing roller ) .
Dec 29, 2008 | Canon NP 6050 Copier
Np 6050 copier
This is from NP6060 I think is the same with NP6050
I have only in italian
maybe you have to chek:
E001 Fuser problem / high temperature / triac / AC driver / pinched wire
Jul 15, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
52 people viewed this question
old marine
old marine
