Question about Canon PIXMA MP830 All-In-One InkJet Printer
MP830 Canon Faxing problem
I am getting a dial tone, I can hear fax sound on the other end when I dial but I get a report printout that says
ERROR TX REPORT.
Pages sent 0
Result NG
  • 3 more comments
  • twins2twins2 Mar 12, 2008
    Yes I have the same exact problem. Can anyone help??
  • Anonymous Mar 24, 2008
    Me, too!
  • TammyCameron Oct 01, 2008
    I tried the solution, but it didn't work for me still getting pages sent 0 result NG. The only way that I am able to send a fax is to hit hook --> dial # --> wait for fax machine to pick up --> hit start.
  • greg151 Oct 24, 2008
    i HAVE THE SAME PROBLEM AND i'VE CHANGED THE ECM VALUE TO off.
  • emaillxd-it Nov 09, 2008
    I have the same problem and changed ECM to off but it still doesn't work.
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Posted on Apr 25, 2008
  • phlebo73
    phlebo73 Sep 10, 2012
    This helped me a lot!! I also had to change the RX setting the same way. Thank you sooooo much!
Great solution (sorry, I clicked Fixya, the best rating, but I am not a Fixya member). Thanks for your help. Canon should advertise with you!
Posted on May 17, 2008
MP830 won't send faxes
Hi. Have you try sending fax to other number maybe the problem is the receiver in the other side of the line .
May 17, 2017 | Canon PIXMA MP830 All-In-One InkJet...
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Daily report/printout
At the end of the each day,press funcktion and then report,select activity report and press "ok"
This is the only way the activaty report can be printed at a spesific time.If you switch the report on in the report settings it will only print when the memory is near full.The other way is to switch TX report to on in report settings,but the you will get a report after every fax that you sent.
Mar 02, 2009 | Canon L220 Plain Paper Laser Fax
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Jan 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Menuel Required Urgently please.
hi!i got the manual for you, its here
hope it helps!
Nov 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon faxphone l80 error tx report tx function was not completed
call the other fax machine with a cell phone, listen for fax tones.
plug a regular phone in the jack to check for a dial tone.
make sure phone cord is plugged into the LINE port of yhe fax machine.
Sep 21, 2008 | Canon Office Equipment & Supplies
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Faxing
did u try to do a hard reset to clear this error?
if nt try it please
Jun 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
Apr 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Jan 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
4,484 people viewed this question
old marine
old marine
