Question about PfaFF Tiptronic 2030
Changing Pfaff 1222 sewing machine belt
I have a Pfaff 1222 sewing machine. the belt started to slip and the machine was clanging and freezing. I changed the outter belt as it was pretty well chewed up. However the machine is still making loud noises and is still freezing. the belt seems to be too big but it is the correct belt. Is there something special I am suppose to do when replacing this belt.
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
Posted on Aug 27, 2008
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
Pfaff 1222 frozen 20 mins after I start using it
My mother has had a Pfaff 1222 for 40 years and loves it. Take yours to a new/different repair shop or find an authorized place for an overhaul. It's not a lemon, just poorly maintained. you have a problem the service people just haven't figured out yet.  If you have taken the same machine to the same people with the same problem more than once and they tell you it's a different cause every time, they are not competent. Also check the owner's manual for any tips.
Jan 11, 2009 | PfaFF Tiptronic 2030
fuse needs replacement
Aug 22, 2008 | Sewing Machines
Pfaff 1222 belt
Hi - a few suggestions:
  1. May just need a good thorough service - generally a good idea to have it completely gone over - by an experienced Pfaff tech - every year or 2. Internal parts can dry out and simply get jammed.
  2. The timing could be off - again an experienced tech can take care of.
  3. The cam-stack (the part that actually makes your stitch formations) may have cracked. At the age of your machine, this isn't uncommon.
At the age of your machine, many other owners actually have it "rebuilt" by an authorized Pfaff service person. This model is one of those that's worth the investment compared to buying a new machine of the same caliber/quality.
If you are comfortable removing the top cover, you may be able to look at the internal parts to see if anything is broken. This will at least give you an idea of what may be happening.
Many authorized techs will not charge you to look at the machine and give you a quote. We'd suggest calling a few sewing machine stores in your area. Don't hesitate to ask friends for their recommendation of a good service person.
Hope this helps - please don't hesitate to respond if you need further info or clarification.
Happy sewing,
Kim & Linnette
Feb 25, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
665 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
