Question about LG RU-42PZ61 42 in. HD-Ready Plasma Television
My lg problem
When i turn on my tv there is two red lines running from top to bottom one on each side of the tv one on the left about two inches from the side and one on the right about four inches from the side they both are about an 1 1/5 inches wide when it first started they would only be on for about 10 min when i first turned the tv on then they would go away now only the one on the right goes away and the one on the left will not they are transparent but they are predominant and i would like to get rid of them for good please help.
jason_turnidge@yahoo.com
  • jturnidge Mar 01, 2008
    thanks is that some thing that you think i can fix my self? i am good with tools and i am a plumber mon-fri where can i order the pannels from?
The left and right Xrlt pannels are probably bad.
Posted on Feb 28, 2008
I have lines on a portion of the left side of my tv
This is a screen-panel issue the only way to fix it is to replace the screen
Jun 26, 2014 | LG 42LC2D 42 in. LCD HDTV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
About two months ago my flat panel plasma tv
Most like likely, this is a panel issue and it will be too cost to fix.
Other things you can try, reseating the ribbon cables on the buffer boards located running across either the top or bottom or both. If that doesn't do it, replace those boards and still no luck. Panel is bad.
Feb 16, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Red line on left side of plasma bright two inches wide
either the address board or the panel has gone bad.
the problem is that many times the address board is part of the panel. if it is under 2 years old you need to
get with lg and push for a new panel
Jan 08, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
42 LG Plasma
It can be fixed but about $300 in parts.
May 18, 2008 | LG 50PX4DR 50 in. Plasma TV
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Red line on screen
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears. 9f78570.jpg
Nov 08, 2007 | LG DU--50PX10C 50 in. Plasma Television
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
LG RU-42PZ61 42 in. HD-Ready Plasma Television Logo
214 people viewed this question
Computer Repairing
Computer Repairing
