posted by sanjayFixya on Feb 25, 2008
The XP Laptop is generating Vertical lines which is making it difficult to view the screen, Is this due to faulty Graphics. I have tried updating the dirvers but did not help. Initially it started as intermittent problem but now it is permamnent. I also tried connecting the laptop to an external monitor and that also displays the same problem.
If it is the card than where can i get a replacement card and fix the problem? IT uses nvidia geforce4 440.
Solution #1
posted on Feb 26, 2008
SINCE THIS WAS AN INTERMITTENT PROBLEM ARE YOU GOING TO BE THE ONE DOING THE REPAIR,IF SO I WOULD CHECK EVERY CONNECTION IN IT.I HAD A SIMILAR PROBLEM AND IT TURNED OUT TO BE THE CONNECTIONS THAT WENT TO THE MONITOR.IT SEEMS TO BE A GRAPHIC CARD PROBLEM BUT I WOULD NOT CHANGE THE GRAPHICS CARD UNTIL I CHECKED ALL CONNECTIONS.AND SINCE YOU HOOKED IT TO ANOTHER MONITOR I WOULD SAY IT IS THE GRAPHICS CARD.I HAVE FOUND LOT OF PARTS AND STUFF ON EBAY.THEY ARE USUALLY THE LOWEST PRICES I CAN FIND.
GOOD DAY
KZ
GOOD DAY
KZ
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Toshiba Graphic Card
Email this problem
Email this problem
Can you Help with these Graphics Cards problems?
Repair Service
Find Graphics Card Repairman Near You:
