Sky and wharfedale DVDR24HD
I have connected the DVD recorder to the Sky box with a scart lead. Also connected to TV with a scart lead (as instructed by Sky installer). The Inital Setup keeps scanning for channels and not finding anything.
Not sure about the HDMI cable?
Can you advise me what to do?
  • gflann Mar 22, 2008
    Try to tune in the Wharfedale DVDR24HD. Have scarts going from Digital Receiver box,to DVD to TV, but when I try to tune in the channels none are being scanned in.
  • TVamp Mar 23, 2008
    Have been trying to attach DVDR24HD to sky box and TV. Have connected DVD to sky with scart and then sky to TV with scart but the dvd player just keeps trying to scan tv for channels. Unfortunately tv has no channels without sky box turned on. Please can anyone help out there.
  • 143 Answers
SOURCE: Sky upstairs
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Posted on Jul 21, 2008
SOURCE: Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Posted on Oct 12, 2008
  • 16 Answers
ok these are called phono leads, yellow = video, red = left sound, white = right sound.
you need one of these there are 2 types, inputs and outputs, this one does both, (you need an output. sky to sender) let me know if this looks right for u
Posted on Jun 07, 2009
  • 325 Answers
SOURCE: sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Posted on Sep 02, 2009
SOURCE: tv flashes when changing channel on sky hd box
Hi I have the same problem I got my TV replaced just today got brand new even better model. and guess the problem is still's not individual,it must be in the whole series. if you have a solution mail at
Posted on Nov 12, 2009
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Cannot tune -in my panasonic vcr. it plays tapes but will not record. I have wired together the tv, sky box and vcr in what seems the obvious way (and every alternative) but no joy so far. can you help?
The main aerial goes into the vcr,a fly lead then comes out of the vcr into the tv,a scart lead from av1 on the vcr into the tv.If you want to record from sky and the vcr has two scart sockets then connect a scart lead from the sky into av2 on the vcr,when you record from sky you select av2 on the vcr as your record channel
Sep 24, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
How do i connect a dvd recorder. to my sky box and t.v
Take the main aerial into the dvd,then a flylead out of the dvd into the tv.Connect a scart lead into av1 onthe dvd and then into the tv.If you want to rec from sky connect scart lead from sky into av2 on the dvd,when you want to record select av2 on the dvd as this is the channel to record the sky on.Hope this helps
Sep 08, 2009 | Televison & Video
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
