Question about Compaq Pavilion ZT3280US Notebook
Pavilion 740n bezel removal
Just need to know how to remove the front bezel on a H.P. Pavilion 740N tower computer?
thank you so much for your information.
john.
e mail me @ roman70816@aol.com
    Genius:
  • 3,587 Answers
Sure..it's most likely either tabs on inside, or screws..you'll need to remove the skins on both sides first, and the tabs may be inside the chassis, instead of nice and obvious to the user.
Posted on Feb 25, 2008
How do I remove the rear cover of Samsung 740N
Service manual:
http://elektrotanya.com/?q=showresult&megnev=Samsung megnev2 = % 20 & 740N = & Category = ALL & kat2
Be real careful when separating the front bezel from the rear casing, you may break the ribbon cable.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 23, 2010 | Samsung SyncMaster 740N (Silver) 17 inch...
740N blank screen
I would inspect all the caps, if you find even one bulging top/leak you should replace them as a set.
See failed SAMSUNG here, use good caps, such as PANASONIC FM or FC series from DIGIKEY.
http://www.badcaps.net
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG megnev2 =% 20 & 740N = & Category = & kat2 schematics
May 02, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
How to open the LCD Casing for Samsung 740N?
htommie, Watch some video clips at YOUTUBE under "LCD monitor disassembly" and or "LCD monitor repair" to see if you really want to do that. The hardest part is "PARTING" the rear plastic cover from the front "BEZEL". You also might find some info at www.ccl-la.com run by another FIXYA guy with nickname "buddymc" Hope this helps. 12fixlouie
Jan 28, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Vertical colored lines on white background on SyncMaster 740N
Hey dont open the LCD in a hurry......the problem may be due 2 usage of LCD 4 long time better dont on the pc for a day........or in night time keep it under the fan.......this may give a better result........
Nov 09, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
My 2 year old Syncmaster 740N often has multiple faint images behind text in any program and multiple faint desktop icons making it look "smeared"; some days worse than others; resolution is correct at...
Well in monitor you can do one thing - disconnect the monitor cable*(VGA Cable) from the tower and chk still if u have the same faint screen that means monitor gone bad if not than uninstall the Grapics Driver and shut down computer... if u have internet than restart and go to device manager ( Run - devmgmt.msc) under display adapter right click on grapics name and update driver.
Oct 14, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I installed a new wireless network card....when removing the outer cover of my pavilion xe734 a black and red wire came loose...it has 3 pins holes a white solid blank then 5 pin holes...i cannot figure...
if the wire is coming from the front bezel of the computer it sounds like your front panel connections. They connect to the motherboard and control your power button and lights. That would explain why it won't power on too! Unfortunately all motherboard connect to the front in different places, but it will always be on the outer edge of the board usually near the bottom of the tower. Try seeing which pins on the board match up. Hope this helps!
Jan 06, 2009 | Computers & Internet
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
How do I open a samsung 740N LCD Monitor
Lift the front frame. You must try to lift it from the inner side using your fingers (no tools , you may scratch the lcd panel). A little force is necessary especially at the corners. Once you lift the panel from all four sides then the corners will come out.
Note: A common problem with this monitor is the psu. A small number of capacitors fails. You will notice 3 electrolytic capacitors have been deformed and if there is no power you will find a small 3A fuse (looks like a resistor) blown.
Sep 30, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Compaq Pavilion ZT3280US Notebook Logo
37 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
