Question about HP LaserJet 2840 Printer
Replace drum I just replaced the yellow ink cartridge and it's now saying to replace the drum. Please help.
  • 152 Answers
Your drum ic in toner goes to down replace it
Posted on Feb 26, 2008
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: replacement of ink cartridges
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Posted on Jan 24, 2008
noisegate
  • 56 Answers
SOURCE: HP Photosmart C6100printer malfunction
try to remove the ink cartridge. check if you we're able to completely remove the plastic packaging. after doing that, with a use of a lint free clean cloth, wipe the metal contacts on the ink cartridge. go to printer properties and go to maintenance tab. you need to register the ink as new. print a test page.
Posted on Sep 17, 2008
SOURCE: says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Posted on Jan 28, 2009
Not recognize yellow and magentadrum cartridges
they may be dry or old stock or out of ink , you need to replace them
Jun 17, 2013 | HP Color LaserJet CM6040f MFP Q3939A...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I have a Brother MFC 3340CN and 1940CN,fax,print,copier I was working fine and then all at one message was yellow out of ink please replace and start again. It has a brand knew yellow ink cartiage in it...
The ink that is given to you when you buy a new machine is not the same as if you went out and bought ink. The "starter" ink cartridges are not filled completely (that is a marketing gimmick to get you to buy more quickly). When you say "NEW" do you mean "new, never been used", or "new, just got it last week"?
If it's never been used, be sure that you have removed the protective tape from that cartridge. If it's been removed then the cartridge its self could have a problem or the machine could be at fault (not correctly reading the ink). You choices are to return it to where you got it, or buy a yellow cartridge and replace it.
If it was working and stopped after a very short time (a week or two) I would get a new yellow and try it.
For your sake I hope it's the protective tape was forgotten, it happens quite often.
Dec 23, 2010 | Brother MFC-3340CN All-In-One InkJet...
The printer says so ink cartridge installed on black.
my hp officejet pro 8500 wont make copies, it says replace yellow ink cartridge. can i not take the yellow cartridge out an still make copies?
Oct 01, 2009 | Brother Multi-Function Center MFC-240C...
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have magicolor 2300 DL.I just replaced Cyan
make sure your cartridge is not stuck and pushed in all the way in printer. If it gets struck it will dump ink out and waste it.
Aug 19, 2009 | Konica Minolta magicolor 2300DL Laser...
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Says the yellow ink needs replacing,have a new ink cartridge in
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
Sep 15, 2008 | Office Equipment & Supplies
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP LaserJet 2840 Printer Logo
286 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
