Question about Sharp AR-168D Copier
Black line when i make a copy through the feed, there's a black line that appears! i tried cleaning the glass but still no luck!
  • jma0923 Feb 26, 2008
    just when i use the feeder
  • brian c
    brian c May 11, 2010
    Does the line only appear when you use the feeder, or also on the large glass?
  • 47 Answers
Try cleaning the scan glass, there should be a thin scan glass that the paper runs over when you use the feeder that may have white out or some other foreign object on it, try cleaning this using rubbing alcohol and a cloth rag
Posted on Feb 26, 2008
I have the SCX-4521. When I feed paper into the top to make copies, the copies come out with a black line in the middle of the page from top to bottom. However, if I make copies by laying the page on the...
Have look where the paper feeds into the tray at the top.
Most likely there is a piece of rubbish stuck in there, another piece of paper or some fluff or something. Blow it out and give it another try.
If this doesnt work open the lid and have a look to the far left of the plate glass. you will notice a small plate glass seperate from the main plate running parallel with the main plate. Clean this with a damp cloth and some window cleaning detergent. Sometimes correction fluid gets wiped off onto this portion which acts as the Scanning Region for documents inserted on the top feeder. This causes a "permanent" black object being scanned for copying, hence the black stripe.
Regards,
BD
Sep 02, 2010 | Samsung Office Equipment & Supplies
I recently installed a new laser cartridge. Shortly after, when copying a document, two black vertical lines began appearing on the copy. What is the fix for this? The black lines do not appear when...
Clean the scanner glass. When I had that problem, I set a copy with lines on it in the scanner feed to see where the problem was, and when I lightly ran my finger on the glass over where the lines were, I could feel two small bumps. I just scraped them off with my fingernail, but here is the HP solution for cleaning your scanner glass:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00062196
Aug 24, 2010 | HP LaserJet 3015 All-In-One Printer
Black line appears in copying from Konica Bizhub 200
If the black line appears ONLY when copying and NOT when printing then you need to clean the adf strip glass. This is the thin strip of glass that is just to the left of the large original glass. Clean this glass very well with a soft cloth and glass cleaner. The line is caused by a small particle stuck to this strip of glass.
Good Luck and Thank You for using Fixya.
Jul 06, 2010 | Minolta Di3510f Bizhub Copier
When I use the automatic feed a blank line appears in t
BLANK or BLACK?, if it's Black, clean the SCANNER GLASS.
Aug 05, 2009 | HP LaserJet 4345mfp Printer
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Black line in auto feed
If you lift the scanner cover, you should see an area on the right end of the platen glass marked at the edge with arrows as Read Area. This is the area used when documents are scanned through the auto feed. Make sure that the glass is completely clean in this area, as any dirt will show up as a line on the copied image.
Apr 18, 2008 | Canon imageCLASS D880 All-In-One Laser...
I have problem with a quality of fax
Make a COPY and see how the copy comes out. If you see the same black vertical lines that other people are seeing, then you probably have something like whiteout on the scan glass.
Open the fax top cover where you feed your originals, and then look inside for a piece of glass about 10" long by 1/2" wide. Then I would try cleaning the glass with rubbing alcohol and also go over it again with windex.
After cleaning the glass, try making another copy to see if it has improved. If it has, but still has more lines, then try re cleaning the glass.
Hope this helps.
Good luck.
Mac
Mar 08, 2008 | Brother FAX-575 Plain Paper Thermal
Samsung sf 330
If you open up the feeder door (Where your originals feed into) you will see a slit of glass going from side to side by the feed rollers. (you might need a flashlight to see it better)
On the slit glass there is probably some white out or something on the glass. All you have to do is clean the glass and this should take care of your problem.
To help you zero in on where the marks might be located, make a copy of a white piece of paper through the fax machine.
And then line up the copy that comes out with your black marks to the feeder.
This should get you in the general location.
If you have any other questions, feel free to post another question.
If I have helped you, please post a feedback and a rating.
Have a good day.
Good luck.
Mac
Feb 23, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Sharp AR-168D Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
