Schematic for ES450 switching power supply.
I have two of the ES450 switchers, to be modified and used in a non-computer application. Please advise availability and cost of schematics
for the units.
Meldrew@hamiltoncom.net
thanks for any help you can provide.
  • Melsan Feb 27, 2008
    for IB4G2008 - the Echo Star SMPS site does not mention anything about the ES450
    supply, just a mod 3000 something supply for a satellite reciever.
    for COOLGUY008 - The site you referenced is about a machine controller (multimedia
    production).
    Sorry, guys, I still need schematics/service manual for ECHO STAR ES450
    switch mode power supply. Thanks for the effort. Keep trying, PLEASE.
    meldrew@hamiltoncom.net
  • Melsan Feb 28, 2008
    Thank you, all who were involved in this search. I incorrectly assumed the tech literature was reasonably available. I am building a test bench for my own use, and need a regulated power supply. I have the parts and experience to scratch-build a well
    regulated adjustable 30 amp linear supply, so will go with that. Thanks again.
    Genius:
  • 3,422 Answers
HI,
Click HERE for the user manual.
I hope this is the one you are looking for.
Goodluck..
Posted on Feb 26, 2008
    Genius:
  • 3,587 Answers
We can find this,,when you provide the maker of the power supplies, please..
Is it possible to repair my Cobra 1500w to 3000w peak power inverter?
As the Cobra 1500w inverter is constructed analogous to a high-frequency "switching" power supply, it is not recommended to modify it to exceed original specifications. For any inverter intended for applications exceeding 2000W transient peak, it is highly recommended to use a low-frequency "true-sine" inverter. Your Cobra inverter is designed for low-deman applications, and is insufficient for high-demand applications.
May 13, 2018 | Cobra Electronics - Others
Marshall MG100HDFX footswitch toggling - bypassing?
I once used uART & some latches to decode & hold the difference between "odd & even" midi program changes. Then used the output to switch a relay in a twin necked guitar to change between necks as it were in response to a midi pedal. Perhaps you could do something similar? Else get a Studiomaster MA-36 midi analyser & hack into it to use one piece of midi data (from across an LED?) to switch channels on your amp? Good Luck!
Jan 16, 2017 | Marshall Music
How to uninstall non responding applications on pc
1 go to start and wright in the searchbox msconfig than enter
2 in the box you find the section with start
there you find the ip switcher and unsigne it from the start list.
3 get the iobit uninstaller and remove the ip switcher.
Sep 18, 2013 | Chris Knox IP Switcher Widget
Behringer XENYX 1620FX, won't power on. Phantom power works(?)
Here is a schematic close to your unit:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links.
The phantom power is a separate rectifier and regulator. See page 11 of the download service manual for the power supply. Be careful when working on line operated switching supplies. I suspect you will find one of the other supplies is dead. If the phantom is OK, then the switcher is working and one of the rectifier/filter/regulators is bad. Check if an electrolytic cap is shorted.
Jul 21, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a Eurodesk 150 watt power supply that will not power up. It may have been struck by lightning. I am looking for a schematic and advice. Thanks, Tommy
You MAY find the schematic is close to one of these:
http://elektrotanya.com/behringer_sps-400_sch.pdf/download.html
or
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
If the main switchers are shorted, then likely the driver transistors are also gone.
Fpr personal SAFETY please use an isolation transformer when working on this.
Hint: Use a 60 Watt light bulb in series with the power input to act as a fuse when unit is "restored" to protect it if not quite all of the blown parts are found, during troubleshooting.
Jan 09, 2011 | Behringer XENYX 2442FX Mixer
Hello. I am a old tech, so struggle a little bit with this unit. It appears that the 12 volt power relay is not getting any signal, thus the 110 is not connected to the first set of power sections. It...
The relay shorts out two power resistors that limit the input power surge. The circuit is complex a bit. An off-line small switching power supply fires up and "heats up" the rest of the circuit for the main power switcher. I have repaired about four of these. Usually a failure due to arcing in the power amp section fries three transistors there and often a Zener diode. This then wipes out the main +/- 70 volt supply. The two IGBT's are usually blown including the four driver traansistors and the switching regulator chip and another small surface mounted transistor and one or both speedup surface mounted 1N4148's. IF THE fuse had been replaced to try again, often the two power resistors (sand coated ceramic) that ar 10 Watt either 10 or 20 ohms will be blown. Some of the hardest thing is to get the heatsinks loose with the IGBT's. When restarting the supply AFTER repair, one puts about 100 Watt lamp bulb in series with the 120 power input to act as a limiting fuse. You will NOT get far with this without a schematic. You can contact me by direct email fredy2 @ aol.com
Oct 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How to connect 4computers with Swith or Hub
A switch or hub isn't very complicated.The primary benefits are connecting more than 1 computer and/or increasing the range of your wired network.
On the back of your switch,all you do is plug in each computer using an ethernet cable,plug in the switch power supply,and turn it on.The only caveat being if you're using 1 PC to connect to the internet,it should probably be plugged into port #1.It probably doesn't matter,but I'm not familiar with your brand of switch.
If this helps,would you please rate my post?
Thanks
Bob
Aug 15, 2010 | Network Computing Devices (NSH800S/A)...
NO POWER EVERY THING CHECKS OKEY The switcher transistor was shorted also the bridge rect. A small resistor was open next to the switcher. H.O.T. okey .I replaced all of these and the tv is still dead....
switch mode power supply are very finicky check the opto coupler isolator of proper operation, also is there a non polarized capacitor at the high or hot side of the power supply, if so replace it, this can be the cause of the fault to begin with, usually around .47 mfd to 4.7, non polarized.
Good luck
Jan 28, 2010 | Sanyo DS24205 24" TV
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
I have an old e machine 500 (origional operating system was windows 98). I am replacing the ATX switching power supply , 230 wat, model lp6100a. My problem is connecting it. I know all the connectors...
The old AT power supply that these old computers uses has two six pin socket connectors and these are different to the ATX connector.
You cannot buy these power supply now, most likely you might find one/computer in a junk shop.
If you have electronic knowledge you might be able to cut off the connectors from the old power supply and connect it to the ATX power supply and modify the ATX power supply so you can switch on the power to the old computer. The old AT power supply uses a mains power switch whereas the ATX uses low voltage to turn on the power supply.
Good luck & have fun.
Nov 29, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Computers & Internet Logo
798 people viewed this question
Alun Cox
David Payne
David Payne
