Question about Vivitar ViviCam 5299 Digital Camera
Size of sd card
Ive seen somewhere recently that i cant use an sd card larger than 1gb, however ive just ordered an sd card which is 2gb. does this mean i cant use the 2gb card in my camera?
    Sergeant:
  • 201 Answers
Hey there harad82, many digital cameras have difficulty formatting and thus difficulty recognising larger size memory cards. This limitation is due to the date of design of the camera, and the only recent availability of the larger memory cards. Also the processor power onboard many cameras is quite limited and cannot handle too much information, such as when one of these cards begins to fill. This can result in lost data. I would suggest you try one before purchasing, perhaps a friend can help with a loner or you can check your cameras specs for limitations on card size. The smaller size cards (512mb or less) rarely cause these difficulties. If you need help with specs please respond with your camera make and model#. Good Luck!
Posted on Feb 25, 2008
What capacity SD card can I use in my Samsung Digimax V800, I was told only 1GB is this true. Thanks
The manual only guarantees cards up to 1GB. However, SD cards go up to 2GB and such cards should work. Cards larger than 2GB are SDHC and will NOT work.
Aug 06, 2011 | Samsung Digimax V800 Digital Camera
1GB card for Kodak C330
The C330 uses MMC and SD cards, up to 2GB in size. You should be able to find 2GB SD cards at just about any department, electronics, or office-supply store. 1GB cards are a little harder to find, as they've been pretty much replaced by 2GB cards. Even if you do find a 1GB card, it's probably not going to cost any less than a 2GB card. There's no disadvantage to using 2GB cards instead of 1GB cards.
Jun 19, 2011 | Kodak EasyShare C330 Digital Camera
Can you use any size memory card other than the 1Gb? Like maybe a 2?
You may use any size SD card. SD cards max out at 2GB, however. Any larger cards are SDHC cards, and they will not work in the C330.
Dec 27, 2010 | Kodak EasyShare C330 Digital Camera
Dear Sir / Madam, I'm using this camera, in its manual it is stated that it supports 1GB SD Memory Card but I tried it with 2GB SD Memory it is detecting and working so should I continue with it or else...
The 2GB one will be ok. When your manual was written, there probably weren't any 2GB cards around, so they only mentioned the 1GB.
However, 4GB or larger "SD" cards won't work. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 25, 2010 | Cameras
What is the maximum size microSD card that can be used?
The A520 uses SD cards. SD cards max out at 2GB in size. A microSD card in an adapter looks exactly like a SD card to the camera, and microSD cards also max out at 2GB. Anything larger is a SDHC or microSDHC card. While they will fit into the slot, they are electronically incompatible and will not work. So, the short answer is: 2GB.
Dec 20, 2010 | Canon PowerShot A520 Digital Camera
W what size SD memory card can i use?can i use
You may use any SD card up to 2GB in size. Make sure you don't try larger SDHC cards, as they won't work.
Nov 17, 2010 | Pentax Optio 50 Digital Camera
It says this card cannot be used. what is the biggest sd card i can use?
The S1 uses SD cards. SD cards top out at 2GB, any larger cards are actually SDHC (Secure Digital High Capacity). SDHC devices will accept SD cards, but SD devices will not accept SDHC cards. They will fit physically but not electronically.
In fact, the S1 manual does not list any cards larger than 1GB.
Jan 26, 2010 | Nikon Coolpix S1 Digital Camera
PNY 2GB SD Card will only hold approx. 350 photos
Depends on the size of each file ( picture). If your shooting a large formate then it could ( that's all you can get on it.
Jun 02, 2017 | PNY 2GB microSD Memory Card
Cannot seem to get my camera to work
The specifications on page 25 of the User's Manual state that only SD cards between 8MB and 1GB in size can be used in this camera. When I tried a larger-capacity 2GB SD card in this camera it reported that the card needed to be formatted even though the SD card worked fine in my desktop PC's SD card slot. Verify that the capacity of the SD card you're trying to use is 1GB or less, I suspect the error report about formatting is due to the SD card being larger than the camera can handle.
Dec 23, 2008 | VuPoint DC-M306AT-VP Digital Camera
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
Vivitar ViviCam 5299 Digital Camera Logo
105 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
