Question about Sharp UX B700 Plain Paper Inkjet Fax
Paper not feeding properly
When I put paper into the fax to copy or send it starts dragging it in at an angle so it doesn't send right. What can i do?
    President:
  • 2,072 Answers
1. Clean the rolllers first.
2, Then on the upper half of the scanner, look for a pad with small leaf springs on it. That pad can be worn or one of the springs bent down. Look into there with a flashlight and see what is dragging on the paper.
Look carefully on the top and bottom half of the scanner, you have some type of partial obstruction.
Posted on Feb 25, 2008
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
fax.
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Paper does not feed right when copying - has a drag to it
Replace the ADF rollers and DFP pad. It could also need the ADF motor assembly. If replacing parts is not an option, them clean the rollers and pad with a soapy solution.
Oct 25, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Paper failure
If you can see the black rubber feed rollers, clean with isopropyl alcohol
Oct 24, 2007 | HP 920 Plain Paper Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
